What Would Happen if a Photon Was Caught Between Two Colliding Black Holes?
The discussion explores the hypothetical scenario of a photon caught between two colliding black holes, focusing on its behavior near their event horizons. It suggests that if a photon were to approach the overlap of the black holes, it would likely be influenced by their gravitational forces, potentially leading to redshift or blue shift effects. The concept of superposition is introduced, where the photon could be in a state of being absorbed by either black hole, resulting in a 50/50 chance of going one way or the other. Additionally, the gravitational tidal forces could stretch the photon's wave properties, altering its color or dispersing it entirely. Ultimately, while the scenario is complex and unlikely, it raises intriguing questions about quantum behavior in extreme gravitational fields.
cragar
This may be a dumb ? , but what would happen if two black holes were coming together and when they were coming together we got a photon extremely close to their event horizons , and when the came together the photon was right on the overlap of their event horizons which way would the photon go , or maybe we could shoot electrons an positrons right in between the black holes and get the emitted photons right on the overlap of their event horizons ,
I realize this is a vary tricky scenario if not impossible scenario but i would like some responses , I mean the forces couldn't just cancel because we can't stop or slow down a photon , would the photon be red-shifted or blue shifted .
Science news on Phys.org
Photon is delocolized and quantum, inherently. If it happens to be heading towards one of the black holes, it will keep going towards it. If it tried to squeeze just between them, but doesn't quite make it, it will go both ways, being in superposition of being absorbed by one black hole and the other. Classical outcome will be 50/50 of it going one way or the other.
how can it go both ways
Quantum physics. Superposition, basically.
good question
may I suggest something?
while it is way way unlikely that the photon will go exactly between the two without first being dragged in one direction or the other during the initial approach (toward the black holes), I think that in the circumstance of the photons that could make it to the middle, would simple have their wave properties stretched and disrupted. Assuming it goes throught he middle on a trajectory that would take it away from the black hole's.
it would look like this- If I shoot a few photons in this "in between" trajectory, I think the light wave property of the photon, would be stretched otu between the two black holes. This would result (obviously) in the permanent changing of colour, if not complete dispersal of the wave itself due to gravametric tidal forces (which, by the way, I am also not accounting for the gravity currents (like water currents) the gravity of two obviously very moving black hole's (the speed of rotation for these two bodies would cause this photon to more likely fall into either holeupon closer approach- and if the black holes weren't moving too much to begin with, they will have tidal forces exchanged between them in their approach)
I would for sure love to learn more about why the other guy though they would split into two photons in superposition though.
Also, I should mention that I haven't mentioned the possible variable of hawking radiation. In the end though, while possible, I think it very unlikely this photon would get through without being stretched into a different colour.
I would like to use a pentaprism with some amount of magnification. The pentaprism will be used to reflect a real image at 90 degrees angle but I also want the reflected image to appear larger. The distance between the prism and the real image is about 70cm. The pentaprism has two reflecting sides (surfaces) with mirrored coating and two refracting sides. I understand that one of the four sides needs to be curved (spherical curvature) to achieve the magnification effect. But which of the...
