Blackbody energy detector, from Liboff's QM
2 replies · 2K views
cstalg
Problem 2.11 of Liboff's Introductory Quantum Mechanics, 1st edition
Suppose that you are inside a blackbody radiation cavity which is at temperature T. Your job is to measure the energy in the radiation field in the frequency interval [tex]10^{14}[/tex] to [tex]89 \times 10^{14}[/tex] Hz. You have a detector that will do the job. For best results, should the temperature of the detector T' be T' > T, T' = T, T' < T, or T' = 0; or is the temperature of the detector irrelevant to the measurement?
There seems not lots of calculation.
I've no idea how such a detector works. Dose it look like a blackbody itself which absorbs the radiation in the cavity?
Your attemp at a solution is halfway to the answer. Keep asking "what if."
The detectors work by absorbing a quantum and converting that event into a signal.
I think the temperature of the detector should be as low as possible, so that no thermal noise will disturb the observation. So it's T'=0. Is that right?
