Block and Pulley System: Acceleration and Tension Homework Solution
  • Thread starter Thread starter NoobeAtPhysics
    Tension
The forum discussion focuses on solving a block and pulley system problem involving three blocks and their accelerations. The correct relationship derived for the acceleration of Block 2, denoted as a2, is a2 = (3/2) * a3 or a2 = (3/4) * a1. The initial attempts incorrectly expressed a2 in terms of a1 and gravitational acceleration (g), which led to confusion. The key insight is that the motion of Block 2 is directly linked to the motions of Blocks 1 and 3, necessitating a relationship based on their accelerations.
  • Understanding of Newton's second law (F=ma)
  • Basic knowledge of kinematics in physics
  • Familiarity with block and pulley systems
  • Concept of acceleration and its relationship in multi-body systems
  • Study the kinematics of block and pulley systems in detail
  • Learn how to derive relationships between multiple accelerations in connected systems
  • Explore examples of frictionless pulley problems to reinforce concepts
  • Investigate the effects of mass and gravity on acceleration in pulley systems
Students studying physics, particularly those focusing on mechanics and dynamics, as well as educators seeking to explain concepts related to block and pulley systems.
NoobeAtPhysics
The diagram shows a block and pulley
system where all the surfaces are
frictionless, and all the pulleys are
massless and frictionless.
Express the magnitude of the acceleration of Block 2, a2, in terms of a1 and/or a3.
F=ma
FBD for block 1
m1 * a1 = T
a1 = T
fbd for block2
m2 * a2 = 2T - m2*g
a2 = [2(a1) -m2*g]/m2
a2 = a1 - g
But i am wrong for some reason..
It looks like the answer is a2=3/2 * a3 or 3/4*a1
Any help would be awesome
Any ideas
The answer is a2=3/2 * a3 or 3/4*a1 which is the solution, I'm not sure how that was achieved.
a2 = a1 - g
Hi NoobeAtPhysics. There is a bit of mind reading involved, but you haven't got to the intended answer only because you have expressed a2 in terms of a1 and g. You are to find it in terms of a1 alone.
There is a relationship you have overlooked, viz., the linking rope dictates that the motion of block 2 is tightly tied (no pun intended :smile:)[/color] to the motions of blocks 1 and 3.
The speed of descent of 2 is the average of the speeds of 1 and 3. The distance through which 2 descends is the average of the distances moved by 1 and 3. Likewise, the magnitude of the acceleration of 2 is related to the accelerations of 1 and 3...
I agree.
Hmm, I still don't comprehend why mathematically the solution is what it is
Can you figure out the simple equation relating the acceleration of 2 to the accelerations of 1 and 3? There is a strong logical hint in the way I worded this:
:wink:
The first step is to establish the kinematics of the motion. Suppose mass 3 is held fixed, and mass 1 moves to the right by 1 unit. How much does mass 2 move downward? Then, suppose that mass 1 is subsequently held fixed, and mass 3 moves to the left by 1 unit. How much does mass 2 move downward? From this, you should be able to conclude that a2=(a1+a3)/2.
Chet
  • · Replies 16 ·
  • · Replies 97 ·
16K
  • · Replies 34 ·
