Block and spring on ramp; find compression
The discussion revolves around a physics problem involving a block on an inclined plane and a spring. The user initially calculated the spring compression using the conservation of energy equation but arrived at an incorrect result. Key points include the importance of accurately defining variables like height, which is influenced by the spring's compression. The correct approach involves recognizing that as the spring compresses, the block loses height, affecting the energy balance. Ultimately, the correct compression distance is found to be approximately 0.1238 meters.
physics8763
Member warned to use the formatting template for homework posts.
An inclined plane of angle
θ = 20.0°
has a spring of force constant
k = 525 N/m
fastened securely at the bottom so that the spring is parallel to the surface as shown in the figure below. A block of mass
m = 2.31 kg
is placed on the plane at a distance
d = 0.312 m
from the spring. From this position, the block is projected downward toward the spring with speed
v = 0.750 m/s.
By what distance is the spring compressed when the block momentarily comes to rest?
I used equation 1/2mv^2+mgh=1/2kx^2 and got x=.084, which was incorrect.
Picture of problem
θ = 20.0°
k = 525 N/m
m = 2.31 kg
d = 0.312 m
v = 0.750 m/s.
Please show your detailed calculations. And don't omit the HW template. That is the rule at PF.
OK, like I said I got x=.084. Basically I have that KE (initial energy) + Gravitational PE is equal to the Work the spring does and solved for x. What did I do wrong?
Most likely there is a bug in the homework grading system. .084 is correct.
what did you use for 'h' ? You wouldn't know how much potential energy is lost unless you've also solved for the distance by which the spring is compressed
Well, did you include the units in your answer?
Units are already included and I substituted dsin(theta) for h
Maybe there isn't a bug. Hmm I am very confused
θ = 20.0°
k = 525 N/m
m = 2.31 kg
d = 0.312 m
v = 0.750 m/s.
Hello physics8763. Welcome to PF.
The equation you show could be used to solve the problem, provided that v, h, and, x are properly defined. (True also for m, g, and k)
Physics is much more than an exercise in "hunting for the magic equation".
That equation suggests that you are trying to solve this problem from a "conservation of energy" point of view.As they say "The devil is in the details.", and you have given us very few details regarding how your equation translated into an answer of x=.084 . (Whatever x is.)
I don't think h is simply d*sin(theta)
Does anyone know how to do the problem?
I need help
Since all of you don't know how to do it I am going to just look up the answer.
Hint: h is a function of x
[Moderator's note: Thread title changed to conform to forum rules. Thread titles must be descriptive of the thread subject matter and identify the type of physics that is involved. Vague titles and pleas for help are not allowed]
Remember that as the spring compresses, the block continues to lose height. What does that do to the energy balance?
I'm sure Steamking, gneill and I all know how to do the problem.
Check what the rules are regarding this Forum. We as HomeWork Helpers must also follow those rules. Putting it bluntly, we do not provide solutions. We are here to help you solve the problem.
Which of these is your desire?
1. The answer.
2. A lesson in how to find the answer.
3, An understanding of the physics involved in reaching the answer.
We can't help with 1. We will help with 2 but only because the goal is 3.
Likes SammyS
Needed quadratic formula: (gsintheta+sqrt(((gsintheta)^2)+(k/m)(v^2+2sintheta*d))/(k/m) gives .1238, the correct answer
