Block, Cart, and Pulley Question
12 replies · 9K views
r34racer01
A cart of mass M1 = 2 kg is attached to a block of mass M2 = 3 kg by a string that passes over a frictionless pulley. The system is initially at rest and the table is frictionless. After the block has fallen a distance h = 0.7 m
a) What is the work Wg done by gravity on the system?
b) What is the increase in kinetic energy DK of the cart-plus-block system?
c) What is the speed |v| of the cart-plus-weight system?
d) What is the work Ws done on the cart (not the block!) by the string?
e) What is the tension T in the string?
I'm really Lost. I can't even figure out what I did wrong when solving for Wg. I did
Wg = mgh = (5kg)(9.81)(0.7) = 34.335 and that wasn't right.
Welcome to PF!
Hi r34racer01! Welcome to PF! :smile:
Hint: work done by gravity = change in PE …
so how much mass is having its PE changed? :wink:
Is it m2 or both masses?
Gravitational PE (potential energy) is caused by change in height.
So how much mass is changing height? :wink:
Oh so it is m2, I forgot also that forces perpendicular to the object perform 0 work, so gravity does no work on m1 right?
Bingo! :biggrin:
Ok so I got Wg =20.601, But now I'm a little confused with finding the change in KE.
work done by gravity = change in PE = change in KE :smile:
Wow I didn't even realize that. So Wg = 20.601. And with that I was able to figure out that |v|=2.87.
So now I'm trying to figure out the work done by the string. We know that the speed is 2.87, so the KE of the cart is 8.32J. I thought I could do 20.601-8.32 to get Ws, but apparently that's wrong. So what should I be doing?
HI r34racer01! :smile:
You didn't realize that? But it's so important
work and energy are the same ("work-energy theorem") …
KE and PE are the same ("conservation of energy") …
see how neatly it all fits together? :wink:
It means that if you want to calculate the KE, say, it's sometimes easier to calculate either the PE or the work done, and use that instead! :biggrin:
i] it's 8.24, not 8.32 :wink:
ii] why do you want the work done … the question doesn't ask for it?
but it's equal to the KE anyway, which you now have.
Then you can find the tension by "reverse-engineering" from the work done. :smile:
Wow thx, but how is 8.24 and not 8.32?
part e.
combine the two masses to find the acceleration using F=ma because acceleration is uniform through the system.
Then use one of the masses and F=ma to determine tension.
This equation would be set up like this:
Winner force - loser force = ma
2.872 = 8.24 :wink:
how did you get 8.32?
