Maximizing Friction Coefficient for Block on a Wedge: A Calculus Approach
The discussion focuses on calculating the maximum coefficient of kinetic friction (µ_0) that allows a block of mass m to slide down a wedge inclined at an angle α. The friction coefficient is defined as µ_0x/d, where x is the distance down the slope. The acceleration of the block is expressed as a(x)=g( sin(θ) - x(µ_0/d)cos(θ)). Two integration approaches are proposed to derive µ_0, leading to conflicting results: µ_0=tan(θ) and µ_0=2g tan(θ). The latter is deemed dimensionally incorrect, while the former is validated as the correct solution.
  • Understanding of Newton's laws of motion
  • Familiarity with calculus, specifically integration techniques
  • Knowledge of friction coefficients and their applications in physics
  • Basic concepts of kinematics and dynamics in inclined planes
  • Study the derivation of motion equations for blocks on inclined planes
  • Learn about the application of the chain rule in physics problems
  • Explore the implications of dimensional analysis in physics equations
  • Investigate the effects of varying friction coefficients on motion dynamics
Students studying physics, particularly those focusing on mechanics, as well as educators looking for examples of friction and motion on inclined surfaces.
Silicon-Based
A block of mass m is placed on a rough wedge inclined at an angle α to the horizontal, a distance d up the slope from the bottom of the wedge. The coefficient of kinetic friction between the block and wedge is given by µ_0x/d, where x is the distance down the slope from the starting point. Calculate the maximum value of µ_0 which will allow the block to reach the bottom of the wedge.
2. The attempt at a solution
After drawing a diagram and resolving the forces I found the acceleration of the block in terms of x:
$$a(x)=g(\sin(\theta)-x\frac{µ_0}{d}\cos(\theta))$$
I don't know how to proceed further, given that the acceleration is defined over x rather than t, which prevents me from simply integrating this expression. I suspect the chain rule could be useful (a=\frac{dv}{dt}=\frac{dv}{dx}\frac{dx}{dt}), but here again, I don't know how x depends on t.
If you rewrite the equation as ##\ddot x+Bx+C=0##, does it remind you of anything?
Alternatively, use that chain rule, but remember that dx/dt is v.
Update:
If I were to integrate the acceleration with respect to time I would get:
$$v(x,t)=g(\sin(\theta)-x\frac{\mu_0}{d}\cos(\theta))t$$ Knowing that the maximum occurs when v(x=d)=0, this equation gives \mu_0=\tan(\theta).
Alternatively, the chain rule gives a=\frac{dv}{dx}v, so $$\int a dx=\int v dv$$ Again, applying the above condition, I end up with \mu_0=2g\tan(\theta). Which one is correct?
Silicon-Based said:
Update:
Neither.
The first is wrong because you cannot integrate x wrt t merely by multiplying it by t. x depends on t.
The second cannot be right because it is dimensionally wrong. You have a dimensionless number on the left and an acceleration on the right. But the method looks ok, so please post your working.
10K
