Blower fitted with De Laval Nozzle
  • Thread starter Thread starter T C
    Nozzle
92 replies · 13K views · last reply
T C said:
As per this page on choked flow, in a convergent nozzle when the speed at the throat reached its limit i.e. sonic speed, no further increase in speed occurs despite increase in input pressure but the number of particles at the throat increase. In short, as the speed can't increase, to keep the mass flow rate constant, the number of particles at the throat increase. Increase in number of particles at the throat means increase in density and that means increase in pressure.
russ_watters said:
That's correct.
No, it's not correct. When the nozzle becomes choked, the speed can absolutely still change, e.g. if the temperature changes. What becomes fixed is the Mach number. It also means that, no matter what you do to the back pressure, the mass flow rate remains constant because the conditions at the throat have not changed, and mass has to be conserved. That said, if you change the reservoir conditions, you can still change the mass flow rate through the throat or the velocity, but the Mach number is still fixed at 1.
russ_watters said:
That - again - is why a typical blower won't work for this application.
As long as the blower can create sufficient pressure on its downstream edges, there is no reason a blower couldn't work in principle. That said, the requirements of CD nozzles will rapidly outpace a blower's ability to keep up.
T C said:
In case of a convergent nozzle, there is no way to measure the speed of the fluid after the throat.
Wait, what? Why do you say this? You can measure speed in any flow if you have the right instrument (subject to the usual constraints of experimental uncertainty).
T C said:
But in case of c/d nozzle or De Laval nozzle, the speed can be measured and it has been found that the speed increases after the flow exits the throat. How that can happen? In my opinion, the increase in pressure at the throat is released and that is converted into more speed at the divergent section.
What I want to say is that the same phenomenon can occur when we use a blower.
This isn't really a matter of opinion. In a subsonic flow, a decrease in area results in a flow acceleration and its complementary pressure decrease (after all, you need a pressure gradient to provide the force for the acceleration). For a supersonic flow, the situation is reversed, and an increase in area results in the same effect (faster flow, lower pressure). In other words, throughout the entire length of a de Laval nozzle, the pressure monotonically decreases and the speed and Mach number each monotonically increase provided that the pressure ratio is large enough to fully start the nozzle.
It makes no difference whether the pressure was provided by a blower or an air storage system. As long as the pressure can be maintained at the desired mass flow rate, then the nozzle runs as designed.
When someone states their dependent variable is is unreasonable/argumentative to add your own.
As long as the blower can create sufficient pressure on its downstream edges, there is no reason a blower couldn't work in principle. That said, the requirements of CD nozzles will rapidlyoutpace a blower's ability to keep up.
I'd be interested to see if such a blower exists anywhere, but again you are reaching beyond the bounds of what was said in search of an error that isn't contained in what was said.
[edit] I can think of a way that might go: since there is no fundamental difference between a "fan", a "blower" and a "compressor", you could take a centrifugal compressor, label it a "blower" and say it fits. It wouldn't be reasonable, but here we are.
Maybe a single stage blower cannot increase the pressure enough from atmospheric pressure - assuming the nozzle outlet pressure is atmospheric as well - but:
  1. No one specified that the blower inlet pressure and nozzle outlet pressure are the same;
  2. One could put blowers in series to increase the potential total pressure ratio.
Like I said earlier, it really doesn't matter how the inlet & outlet conditions are created at the nozzle. And the inlet conditions depends on the blower inlet conditions as well - if such machine is used (but it really doesn't matter if there is one or not).
I don't know what this means, but I don't think what I said was in any way unreasonable. There were some misstated facts about how de Laval nozzles operate, and I thought it important to straighten those out in the context of this thread. That doesn't make me unreasonable. In fact, it is important to understand that, in order for any of the previous assumptions about speed here to be true, one must hold the temperature constant. That is remarkably difficult to achieve at times with compressible flows, especially when we are talking about using some kind of blower that is not doing anything to control for temperature changes.
Blower, fan, compressor... they all operate in fundamentally similar ways. They take air from an inlet at (presumably) atmospheric pressure, and use the powered motion of the blades to increase the pressure just downstream, which provides the pressure required for the application in question. A box fan has a relatively small pressure ratio, and on the other end, a jet engine has a very high one. Since @T C did not really specify at all what he is using, it is not really possible to determine what sort of system he or she actually has.
The statement you responded to (which I agreed with) was: "...no further increase in speed occurs despite increase in input pressure..." It doesn't mention temperature, so it is reasonable to assume the intent is for temperature to remain constant. It is unhelpful and argumentative to go beyond the bounds of what was stated (without at least dealing with the statement as given). For example, a more reasonable response would have been: "That's correct as stated, but be careful; there are other things not mentioned, such as temperature, that could be changed that you didn't mention, that could allow the speed to change."
Agreed. So do you think it is reasonable to assume the OP has a device that has a label that says "compressor" on it, but he called it a "blower" instead?
It would be more helpful if you tried to answer the OP's questions in a way that makes a reasonable effort to interpret the question in the way the OP intended...and for that matter, apply that to other posts/posters as well. Otherwise, you are going off on tangents that distract from the question being asked.
Do you mean like the 5 post discussion I had with the OP before you even joined the thread or the several in depth posts I provided after that walking him/her through nozzle calculations?
If you want to nitpick about the topic of the original post, the. Go read it yourself. OP specifically asks about achieving a certain flow velocity, which is intimately and undeniably related to the flow temperature. The fact that OP did not mention temperature does not somehow make it irrelevant. Based on the context of this actual post, it is more likely that OP did not know it was important, making it still more important to discuss.
You offered a bit of advice that was factually inaccurate and potentially misleading with regards to what it means for a nozzle to be choked and in the context of this thread. For example, in reality, OP wants a certain outlet velocity (400 m/s). If instead they wound up with 350 m/s, my post and reality suggest OP could add some heat to the flow to raise that speed even though the nozzle is choked. Your post suggests that is not a viable route to take.
So far, all the discussions are based on pressurised air releasing through a nozzle while what I was asked about a blower fitted with a c/d nozzle. When compressed gas is released through a nozzle, it has higher pressure but zero initial velocity while in my case the the fluid enters with nozzle with a specific velocity.
russ_watters said:
As you make the nozzle smaller, the airflow profile will ride the blower curve until it reaches a maximum pressure at which point you've reached your maximum velocity...and it may stall and drop the pressure/velocity
What can be that maximum velocity?
You have to convert to stagnation (or total) properties: stagnation temperature, stagnation pressure. These properties are usually denoted with a zero subscript (##T_0##, ##p_0##). This will represent the equivalent "reservoir" (with zero initial velocity) that can be compared to your compressed gas with initial velocity.
My gas isn't compressed. It enters the nozzle with a specific velocity.
It still has an absolute pressure, even if it is atmospheric pressure. With this absolute pressure ##p## and the Mach number ##M##, you can find the total pressure ##p_0## (see the links in my previous post).
bd49940ef1bae4d1678978083add2380f3ed6053
Whether you know it or not, it is compressed. Your blower, however it operates, is compressing the air entering the inlet and exhausting it with a higher total pressure and likely a slightly higher temperature. This total pressure and temperature are what will determine what you can and cannot achieve through a de Laval nozzle.
By absolute pressure, do you want to mean a summation of static and dynamic pressure?
Absolute pressure means pressure referenced to zero (as opposed to gauge pressure, referenced to atmosphere).
Total pressure is the pressure that occurs if a flow is isentropically slowed to zero velocity (sometimes called stagnation pressure). For an incompressible flow, it equals the sum of static and dynamic pressure. For a compressible flow, it does not. Your flow here is compressible.
Actually there is a basic difference when compressed air is used and when a blower is used. In case of compressed air, we can assume that it has been compressed adiabatically and then left to cool down so that the temperature can come to ambient level. That means a big part of the energy spent in compressing the gas is lost as heat. And also when this gas is released, then it expands adiabatically and thus its temperature falls.
But in case of a blower, the case would be like a compressor where the gas is compressed adiabatically and then released instantly without being cooled. The formula that Jack Action has mentioned has the temperature parameter but in the formula, it isn't mentioned whether the temperature is before being released or after being released.
What bonehead is trying to tell you though is that it doesn't matter. You say
but we can suppose whatever reservoir conditions we would like. In Jack's formula, the temperature is the temperature just upstream of the nozzle (technically, the stagnation temperature just upstream of the nozzle, but as long as we suppose the exit to your blower is well below mach 1, this will basically be the exhaust temperature of the blower). There's no fundamental difference between your blower and a reservoir with the same temperature and pressure located upstream.
There are absolutely no differences.
The cool down period you refer to, is actually a decompression.
That is what I've been trying to tell you all along. All equations you will find for a nozzle (or any turbomachinery for that matter) refer to the inlet and outlet conditions of that nozzle.
What are the pressure, temperature and Mach number of the fluid a the inlet? That is all you need to know. How you got there doesn't matter. Whether you compress the gas with an axial turbine followed by a long cooling journey through a pipe OR that your nozzle is facing a strong headwind caused by a tornado OR that you connect the nozzle to a heated box filled with your gas:
If the result inlet gas conditions (pressure, temperature, Mach number) are the same - and assuming the nozzle discharges in the same environment - the result will be the same.
Apart from all of the above, since he apparently has the blower in question at hand, whatever it is, all that is necessary to determine the stagnation pressure is a ram tube (funnel) connected to a pressure gauge to determine the stagnation pressure at his blower outlet and a thermometer to determine the discharge temperature.
Maybe I am missing something here, but this may not be enough. The shape of the CD nozzle may alter the output of the blower as well if it can't keep up with the mass flow rate at the given pressure required to start the nozzle.
This is only a first step to determine if the blower discharge pressure at its current mass flow is capable of a pressure sufficient to support a sonic flow in a nozzle throat. If so, then the appropriate nozzle throat size would be selected that would provide a sonic nozzle throat velocity without creating any additional backpressure on the blower. Since the blower discharge velocity will not be changed from its current condition there will be no risk of creating sonic flow at the matching nozzle entry connection; and, then the sizing of the diverging nozzle discharge would be based upon providing the desired increase in final discharge velocity.
This all assumes that the current blower stagnation pressure is sufficient to providing a nozzle throat pressure high enough to create a pressure at the nozzle discharge, after expansion, high enough to exceed the downstream back pressure of the system and attain the desired supersonic discharge velocity.
The target is to be able to increase a velocity at the C/D nozzle discharge velocity greater than that currently provided by the blower at its current design capacity.
Others have responded that your gas is compressed, but that is unlikely to be true in a realistic sense. The only thing you have told us about your blower is that it can generate 100m/s flow. That's actually right on the edge of what is typically considered incompressible. Strictly speaking, any airflow requires compression, but it is generally ignored up to 100m/s and considered incompressible to make the calculations easier.
Your blower - again, since you haven't told us what it is, I'm assuming - likely generates 100m/s at the outlet, where the static pressure is zero, so it can be considered incompressible.
Ironically, though, while you think this helps you, it doesn't. As we keep trying to tell you, over and over and over and over and over and over again, generating supersonic flow requires compression. The fact that you aren't doing it (or, rather, are doing very little), is the reason why you can't achieve supersonic flow.
Here is a selection for the highest pressure blower you're likely to find:
180 inches of water gauge is 6.5 psi or an available pressure ratio of 0.69. That's a lot better than I would have expected, but still quite a bit above the maximum required for choked flow of <0.5. And it requires 170 horsepower for just 200SCFM of airflow. That's like a midsized car engine at full throttle to run a bathroom fan.
Oh! Is that what HVAC guys call a "blower"?
Try a Roots-type blower, you can achieve 2:1 pressure ratio easily:
Funny how we see different things from the same statement.
Wow, thanks, I hadn't heard of that. And it fits nicely into the nomenclature overlap, being referred to as a blower, a pump and a compressor in the same article! I would say that's confusing, but it really is in an overlap range: the flow is definitely compressible even though the pressure is below what is common for "compressors".
I'd like to point out that 100 m/s could be considered compressible depending on the local speed of sound (which depends on temperature). That's unlikely here since the air is likely warm. The flow through the blower is very possibly compressible, though.
Also, the requirements to choke a CD nozzle are typically greater than the common 0.528 pressure ratio (##p_b/p_0##). Running it without any shocks so the exit velocity is supersonic requires a lower ratio. The 0.528 number is for converging nozzles only.
Actually, it is a simple "air displacer". The air gets into a chamber and the chamber rotates towards the outlet. If you put it in front a restrictor (ex.: an engine with a smaller defined volumetric flow), then the pressure will accumulate between the two, i.e. a compression. So it is in fact a «blower».
There is also a screw type compressor which looks a lot like a roots type, but it actually compresses the air within (the chamber decreases in size as it moves), so it is a compressor. That is why they are more efficient than Roots type.
Here's the cute history of its origin:
http://www.mini-blowers.com/roots-blower-history.php said:
The Roots device is a positive displacement pump, used as an air pump or fluid pump. It moves air, but does not compress. The basic design was patented in 1860 by Philander Higley and Francis Marion Roots (hence the name) of Connersville, Indiana, as an air pump for mines, grain elevators, blast furnaces, and other industrial applications. As an air pump, it pulls air by trapping it with meshing lobes against the outer side of the blower case and pushes air from the intake side to the exhaust side. In an engine application, when pumped into a confined space such as an intake manifold, positive pressure is developed, along with an increase in temperature of the pressurized air (not a good thing). An intercooler can be used to help cool the charged air.
While we are listing the available types of compressors it would be unfair not to include the sliding vane type as well.
A centrifugal compressor can push a pressure ratio of 4:1 or more per stage, with very high airflow. You could easily size a blower that would start a C-D nozzle, and maintain the flow rate to keep it operating, although the power rating would necessarily be extremely high. As an extreme example, multistage axial jet engine compressors can flow hundreds of kg/s of air with a pressure ratio of 40 or 50 to 1, but they require powers on the order of tens of megawatts to drive.
One question just comes to my mind against boneh3ad's post no. 19. If a turbogenerator is used to produce power by using the velocity of the released air/fluid, does that alter the temperature or remain the same? Suppose that the turbine blades can withstand the blow of liquid oxygen droplets.
When a gas flows through a turbine, it does work against the turbine, expands and cools.
I know that and that's why I want to know whether in such case the fall in temperature will be same or more.
