Bluetooth for Can Size Satellite Transmissions
  • Thread starter Thread starter ws0619
    Bluetooth
Using Bluetooth for satellite communications is impractical due to its short-range capabilities, which are insufficient for data transmission from low-earth orbit to ground stations. Legal regulations require licensing for any frequency used, including the ISM band, which has strict power limitations. Modifying Bluetooth devices may not be feasible, as high-gain antennas could violate FCC rules. Additionally, Bluetooth is designed for low-power applications, making it unsuitable for long-distance communication. Overall, traditional FM radio frequencies remain the preferred method for satellite data transmission.
ws0619
Bluetooth can use??
Hi!I am planning to make a can size satellite.Normally we use FM(radio frequency) to transmit data from satellite to ground station.But can i use Bluetooth to replace FM?I know that Bluetooth is short-range frequency so any idea to solve this problem?Thanks!
Well, if you could, you would be committing a federal crime. What frequencies do you have authority to transmit on?
As Halls says, you need to be licensed in whatever band you use, unless you use the SIM band. And even in the ISM band (aka the "microwave oven band"), you are limited to something like 5W of power (I forget the numbers right now). With very directional antennas, you might be able to make it from low-earth orbit to the ground, but the antenna will be more like a meter long and 7-10cm wide. That's bigger than your satellite...
Thanks for advising me. But can I just buy a Blutooth device to modify it? Is it need license too?
I don't know the FCC rules for putting high-gain antennas on BlueTooth devices. You could try asking at one of the BlueTooth online web forums.
I think power might be an issue as well. BlueTooth is optimized for short range applications, and power is limited to help avoid multi-device interference. You will need some power to get from orbit to the ground, depending on the frequency and type/size of antenna.
Thread 'I thought it was only Amazon that sold unsafe junk'
I grabbed an under cabinet LED light today at a big box store. Nothing special. 18 inches in length and made to plug several lights together. Here is a pic of the power cord: The drawing on the box led me to believe that it would accept a standard IEC cord which surprised me. But it's a variation of it. I didn't try it, but I would assume you could plug a standard IEC cord into this and have a double male cord AKA suicide cord. And to boot, it's likely going to reverse the hot and...
