What Is the Fastest Way to Cross a Flowing River by Boat?
  • Thread starter Thread starter rasen58
    boat river time
The fastest way to cross a flowing river by boat is to travel straight across. This conclusion is based on the principle that the shortest distance minimizes travel time, despite the river's current. While the x component of distance remains constant, the x component of velocity varies depending on the angle of approach. Only by heading directly across the river does one achieve the maximum horizontal velocity, thus reducing overall crossing time.
  • Understanding of basic kinematics principles
  • Knowledge of vector components and their implications
  • Familiarity with the concept of relative motion
  • Basic physics of fluid dynamics
  • Study vector resolution in physics to understand velocity components
  • Explore the principles of relative motion in flowing fluids
  • Learn about the effects of current on boat navigation
  • Investigate real-world applications of kinematics in water travel
Students studying physics, educators teaching kinematics, and anyone interested in optimizing boat navigation across flowing water.
rasen58
How should you travel across a flowing river in a boat to minimize your time of travel?
A) Straight across
B) Slightly upstream
C) Slightly downstream
D) The time will be independent of how you head
I thought the time would always be independent of the direction because the x distance is constant whichever way you head. I was remembering a kinematics problem that is similar to this and I thought in that problem it didn't matter which way you headed.
But the answer is straight across, and while it makes sense because that is the shortest magnitude of the distance, I thought it would only depend on the horizontal component which is always the same. What am I not seeing?
The x component of distance is constant regardless of which way you head. But is the x component of your velocity constant?
Why wouldn't it be constant if it's not accelerating in the x direction since its traveling perpendicular to the river current?
My apologies for writing confusingly.
The x component of velocity will be constant for any given angle. But it will not be the same for each angle.
Oh I see, I guess that's true. Only if you go straight across will you have the greatest horizontal velocity.
This is quite ambiguous. Does it mean relative to the water (i.e. which way should you point the boat) or relative to the shore?
10K
  • · Replies 22 ·
