Boatswans Chair pulley Question
  • Thread starter Thread starter Ryansf98
    Pulley
The discussion revolves around a pulley system involving a man and a chair, focusing on the forces acting on them and the tension in the ropes. Participants are exploring the dynamics of the system, particularly how tension relates to weight and acceleration.
  • Participants discuss the concept of tension in the ropes, questioning how it relates to the weight of the man and chair. They explore the implications of equal tension throughout the rope and the effects of multiple ropes on the net force acting on the system.
The discussion is active, with participants providing insights into the free body diagrams and the forces involved. Some have suggested drawing diagrams to clarify the forces, while others are questioning the assumptions about tension and weight. There is a productive exchange of ideas regarding the number of ropes and their contributions to the net force.
Participants are considering the implications of Newton's laws and the characteristics of the pulleys, such as whether they are massless and frictionless, which affects the tension in the ropes.
Ryansf98
The question has been screenshotted, along with the given diagram. Basic stuff I know, but I can't seem to get my head around pulley systems. T
F(net) = m ⋅ a(system)
I understand the rope to be considered inextensible. Also, I understand that the tension must equal the weight of the man & chair, but beyond that I don't know how to break it down.
I labelled a reference frame with x being positive down.
Hi Ryansf98,
Welcome to Physics Forums!
What leads you to that conclusion?
Have you made a free body diagram of the man&chair?
gneill said:
Hi Ryansf98,
Welcome to Physics Forums!What leads you to that conclusion?
I just read that over and now realize it doesn't make sense, as equal tension & weight would mean an acceleration of 0m/s^2 wouldn't it? What I meant was that tension must be equal throughout the rope.
Okay. Draw the resulting free body diagram for the man&chair.
gneill said:
Hi Ryansf98,
Thank you by the way! I've used it for sometime looking at existing threads, but I couldn't find an existing problem like this one so thought it'd be a good time to start my own account!
I done that, labelling F(down) as 200N + mg, => F(down total) = 887N.
Regarding the tension, I labelled T moving up from the man to the smaller pulley. Would that then split into 1/2T either way up the pulley, or would it remain T?
I also labelled T pointing up on the rope which the man pulls down on.
I realize I jumped a gun a little there as you only suggested a free body diagram for the man and chair. For this, I labelled mg down and T up towards the smaller pulley. Would I in fact insert 200 N here also?
How many ropes attach to the man&chair? If each has a tension T, what's the net force upwards?
One rope attached directly to the man and chair, therefore T up? Also, would 200N be T, due to Newtons 3rd Law?
Therefore, Net Force Up = 200N?
In fact, there are 3 ropes above the man and pulley, therefore F(up) = 3T.
T = 200N as the man exerts this force down the rope and so the rope exerts this force up on him.
That means that F(net of the system) = mg - 3T, => 686.7 - (3*200) = 86.7N downwards.
F = ma, a= 86.7/70, => a = 1.24 m/s^2?
No, there are two ropes connected to the man and chair: One he holds directly, one connected to the chair.
The one he holds has a tension T = 200 N. What's the tension in the other rope? (consider a FBD of the small pulley).
F = ma, a= 86.7/70, => a = 1.24 m/2^2?
Yes! That's much better!
So generally no matter what, each rope has a tension T throughout the system, even if the rope reaches a pulley and looks to go into 2 separate ropes?
Thanks for the help!
If the pulleys are massless and frictionless, then continuous ropes have the same tension. When separate ropes meet at a pulley, their tensions sum (vector sum).
Makes sense. Again thanks for your help!
  • · Replies 18 ·
  • · Replies 22 ·
  • · Replies 22 ·
  • · Replies 18 ·
  • · Replies 22 ·
