Bode Plot - Calculating ωgc and ωpc analytically
The discussion focuses on calculating the gain crossover frequency (ωgc) and phase crossover frequency (ωpc) analytically for Bode Plots. Users express that while graphical methods yield good results, discrepancies arise when calculating ωgc mathematically, especially at low gain levels. A specific example illustrates that the calculated ωgc (1.57 rad/s) differs significantly from the graphical value (2 rad/s), raising questions about the reliability of analytical calculations versus graphical methods. It is emphasized that understanding the poles and zeros of a system is crucial for effective Bode Plot design, and that calculations should ideally be avoided when using Bode Plots for system design. Overall, the conversation highlights the complexities and challenges in accurately determining frequency characteristics in control system design.
phiby
I am learning to draw Bode Plots. I am able to figure out ωgc, ωpc, Phase Margin & Gain Margin graphically from the Bode Plot. But I was wondering if there is a way to calculate ωgc and ωpc mathematically with some formulas - how do I do this?
There is the Laplace transform that converts a time domain equation to an "s" domain equation, where
s = i\omega
or
s = \sigma + i\omega
In this case, the time domain equation might be some differential equation that defines the behavior of a filter.
I calculated ωgc analytically & compared it to the one I got from a Bode plot.
When Gain is rather low (say 2), then the calculated ωgc varies a lot from the one obtained from an asymptotic Bode Plot.
For eg.
let's take
G(s)H(s) = 80/(s)(s+2)(s+20)
= 2/(s)(1 + 0.5s)(1 + 0.05s).
In this case the ωgc is very close to where the approximation error happens for the first cornering frequency (2 rad/s - corresponding to (1 + 0.5s)).
My calculated ωgc = 1.57 rad/s.
The one on the graph (where the Magnitude plot intersects 0) is around 2 rad/s.
On a semilog paper the horizontal distance in the 2 lines (ω = 1.57 & ω = 2) is rather big.
Is this a known issue?
I use Bode plot for years to design all sort of closed loop control systems and I consider myself pretty good at taming them. I never get into the s-plane stuff. Bode plot and the ωgc is almost two different thing, you draw your Bode plot from knowing the pole and zero frequency of the system, not the other way around. When you use Bode Plot, you try to avoid all the calculation and use graph to design the system. If you want to do calculation, don't use Bode Plot.
When you design a closed loop system, you measure the system poles and zeros and design the amplifier circuit with poles and zeros to get single pole cross over with enough phase margin. Identifying the system poles and zeros are the most difficult part.
When you identify all the poles and zeros of the system, your job is over 90% done, the rest is just defining which part belong to the forward gain and which part be the reverse feedback and draw the Bode plot and add your own gain, poles and zeros to get the single pole cross over with phase margin!
i remember calictlating phase cross over frequency by equating argument of open loop transfer function to -180 degrees and gain cross over frequency by equating magnitude to 1. . .
Thread 'I thought it was only Amazon that sold unsafe junk'
I grabbed an under cabinet LED light today at a big box store. Nothing special. 18 inches in length and made to plug several lights together. Here is a pic of the power cord: The drawing on the box led me to believe that it would accept a standard IEC cord which surprised me. But it's a variation of it. I didn't try it, but I would assume you could plug a standard IEC cord into this and have a double male cord AKA suicide cord. And to boot, it's likely going to reverse the hot and...
9K
