quZz
- 123
- 1
If it takes 10 min to hard boil 1 egg, how long will it take to boil 2?
Boiling multiple eggs does not significantly increase the cooking time. Empirical data shows that while one egg takes approximately 11 minutes to hard boil, three eggs require only 7.5 minutes, leading to a calculated time of 9 minutes and 15 seconds for two eggs. The discussion emphasizes that as long as the water is boiling, the number of eggs does not affect the cooking duration, although starting temperature and pot size can influence the overall energy required.
PREREQUISITESCulinary enthusiasts, home cooks, and anyone interested in optimizing egg boiling techniques and understanding the science behind cooking times.
KartikAddanki said:Does it not take more energy to heat two eggs rather than one egg? I always thought a larger egg will take more energy to heat the internal temperature than a smaller egg. Similarly, a larger pot of water should take more energy to raise to the same temperature, shouldn't it? :\
Excellent. Now we have empirical data.Danger said:I cook 3 at a time...
...simmer for exactly 7 1/2 minutes.
Put one egg in a pan of water and put them on a burner. Put the other egg in a second pan of water and put it on a second burner. Turn them both on. Ifr it takes 10 min to hard boil 1 egg, it will take 10 min to hard boil 2 eggs (or 3 eggs up to however many burners you have on your stove!quZz said:If it takes 10 min to hard boil 1 egg, how long will it take to boil 2?
Danger said:Sometimes I truly wonder about you, Dave.![]()
I boiled 42 eggs once. I can't tell what happened - copyright issues, mostly.DaveC426913 said:Then you'll really start to wonder when I tell you how long it takes to boil 8 eggs...![]()
turbo-1 said:I boiled 42 eggs once. I can't tell what happened - copyright issues, mostly.
Shai-Hulud said:I don't suppose it really matters how many eggs you put in the pot. If I remember correctly, water maintains a constant temperature while boiling, so as long as the water is boiling, all of the eggs should be getting the same amount of heat. Adding eggs may make it so that it requires more energy to keep the water boiling, but as long as it is boiling, it will take ten minutes regardless.
That's OK. I have no experience insulting yolks.pixel01 said:...When you start at 100 oC (put in the egg when water boils), the outer shell (not the yolk) is boiled and hardened so the yolk is almost insulted and you lose most of the heat from the stove...
I have no experience of boiling more than 3 eggs
DaveC426913 said:I have no experience insulting yolks.![]()
DaveC426913 said:That's OK. I have no experience insulting yolks.![]()
