How Do You Prove the Bolzano-Weierstrass Theorem?
  • Thread starter Thread starter maximus101
    Theorem
The Bolzano-Weierstrass Theorem can be proven by starting with axioms such as the least upper bound property or monotone convergence. An approach involves demonstrating that every infinite sequence contains a monotone subsequence, which can either be infinite or finite. If the subsequence is infinite, it is a decreasing sequence, while if it is finite, one can construct a decreasing subsequence by selecting indices that lead to smaller values. The theorem follows from the fact that a bounded sequence will have convergent subsequences, whether they are increasing or decreasing. Thus, the existence of a convergent subsequence is guaranteed for any bounded sequence.
maximus101
Hello, please could someone explain how to prove the Bolzano-Weierstrass Theorem?
thank you
Mathematics news on Phys.org
Starting from what axioms? It is possible to take "Bolzano-Weierstrasse" as an axiom for the real numbers and prove other properties (such as the Cauchy Criterion or least upper bound property from that. But it is more common to start with the least upper bound property or monotone convergence as an axiom.
You can, for example, prove that every infinite sequence contains a monotone subsequence:
Let \{a_n\} be a sequence of real numbers. Then Define the sequence \{a_{i}\} for i in some subset S of the positive integers by: i is in S if and only if a_i\ge a_m for all m> i. That is, a_i is in the subsequence if and only if a_i is greater than or equal to all subsequent numbers in the sequence. Of course, it is quite possible that this subsequence is "empty"- for example, if the sequence is increasing, this is never true. It is also possible that the subsequence is non-empty but finite. Or it is possible that the subsequence is infinite. For a decreasing sequence this "subsequence" is, in fact, the original sequence.
Now there are two cases:
1) This subsequence is infinite.
Then we are done! This subsequence is itself a decreasing sequence.
2) The subsequence is either empty or finite.
Then the set, S, of indices, is empty of finite. If finite, then there exist an index, i_1 that is larger than any number in S (If empty, i_1= 1 will do). Since i_1 is not in S, there must exist i_2> i_1 such that a_{i_2}< a_{i_1}. Since i_2> i_1, and i_1 was larger than any number in S, i_2 is not in S and so there must exist i_3> i_2 such that a_{i_3}< a_{i_2}. Since i_3> i_2> i_1 it also is not in S and so there exist i_4> i_3 such that a_{i_4}< a_{i_3}. Continuing in that way we get a decreasing subsequence.
Now Bolzano-Weierstrasse follows easily from monotone convergence- If \{a_n\} is a bounded sequence then it has both upper and lower bounds. If that monotone subsequence is increasing, it has an upper bound and so converges. If that monotone subsequence is decreasing, it has a lower bound and so converges. In either case, a bounded sequence contains a convergent subsequence.
subdivide.
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
