Can Born Rigid Motions Occur in Curved Spacetime?
The discussion revolves around the possibility of Born rigid motions occurring in curved spacetime, particularly focusing on the behavior of rotating spheres or disks under the Born condition of rigidity. Participants explore theoretical implications, mathematical definitions, and the relationship between rigid motion and spacetime curvature.
  • Some participants assert that a sphere or disk rotating with uniform speed can follow the Born condition of rigidity.
  • Others reference the Ehrenfest paradox, suggesting it indicates that a rotating disk cannot be perfectly rigid, particularly when transitioning from rest to rotation.
  • One participant clarifies that the Ehrenfest paradox shows that a disk cannot maintain rigidity if its angular velocity changes, but a disk rotating at a constant angular velocity can be considered rigid.
  • A participant introduces a mathematical framework for understanding rigid motion, mentioning the requirements of zero expansion and shear in the vector field representing the motion.
  • Another participant notes that rotational Killing motions exist and correspond to rigid rotations with constant angular velocity.
  • Some participants discuss the applicability of Born's conditions to any uniformly rotating object, not just spheres, while emphasizing the need for constant angular velocity and limitations on speed.
  • There is an acknowledgment that assumptions about flat spacetime are made, with a suggestion that Born rigid motions may also be possible in curved spacetimes, albeit with different characteristics and limitations.
Participants express differing views on the implications of the Ehrenfest paradox and the conditions under which Born rigid motions can occur. While some agree on the possibility of rigid motion under specific conditions, others highlight the complexities and limitations, indicating that the discussion remains unresolved.
Participants note that the discussion assumes flat spacetime of special relativity, with some acknowledging that the conditions for Born rigidity may differ in curved spacetimes due to the presence of fewer Killing vector fields.
Tahmeed
Can a sphere or disk rotating with uniform speed follow born condition of rigidity?
Yes.
pervect said:
Yes.
Are you sure about that? I thought that Ehrenfest paradox showed that a rotating disk can't actually be perfectly rigid.
As far as i know, Ehrenfest showed that it can't start rotating without breaking Born condition for rigidity. But my knowledge is very limited. And I would however request 'Mr.Pervect' to elaborate. I didn't find sufficient resources on this issue.
No, it just shows that you can't take a disk that isn't rotating and make it rotate while keeping it perfectly rigid. In other words, the motion of a disk that is rotating at a changing angular velocity is not a rigid motion. But the motion of a disk that is rotating at a constant angular velocity is a rigid motion.
A not particularly readable (IMO) reference on the topic is "The Rich Structure of Minkowskii Space" https://arxiv.org/abs/0802.4345. The notion of motion is described abstractly by a vector field ##u^a##, the integral curves of this vector field are the worldlines of particles on the body whose rigidity is to be tested. "Rigid motion" is a specific mathematical requirement that the vector field representing the motion must meet.
There's a couple of different ways of describing the mathematical requirements for the motion to be Born rigid. One of the more convenient ways is to say that the expansion and shear of the vector field u is zero. There's also an approach using Lie derivatives, which may be simpler in some respects. I believe from context that Born's original expression of the condition was in terms of the Lie derivative, for what it's worth.
The definition in terms of the expansion and shear is proposition 17 in the above reference:
Proposition 17.
Let u be a normalised timelike vector field
The motion described by its flow is rigid iff u is of vanishing shear and expansion
Also of interest is the following:
Vector fields generating rigid motions are now classified according to whether or not they have a vanishing vorticity ω : if
ω = 0 the flow is called irrotational, otherwise rotational. The following theorem is due to Herglotz and Noether:
Theorem 18 (Noether & Herglotz, part 1)
A rotational rigid motion in Minkowski space must be a Killing motion.
Rotational Killing motioins do exist - they're just the motion of a rigid rotating disk. The paper even writes down the vector field of such a moton (using notation in which partial derivative operators are used to describe vectors) - it mentions that
This motion corresponds to a rigid rotation with constant angular velocity κ
Sorry if this is all too advanced, the complexities of a fuller explanation are why my first answer was just "Yes" and not more detailed.
It is actually too advanced for me anyway, haha. However, does this only apply to spheres or anybody rotating uniformly?
Given that a sphere can rotate so as to satisfy Born's conditions any subset of the sphere will also satisfy Born's conditions. So the basic answer is yes.
Some necessary conditions for a sphere to satisfy Born's conditions are that the sphere rotate with a constant angular velocity (it won't satisfy Born's conditions if it's rate of rotation varies with time), and that the sphere be small enough so that all parts of it move at less than the speed of light.
An assumption I make in giving this answer is that the space-time is the flat space-time of special relativity, not the curved space-time of General Relativity in the presence of significant mass. Rather than say this is necessary, I'd say that this is assumed.
Born rigid motions are possible in at least some curved spacetimes as well, but they will in general not be the same in terms of the "shape" of the object as they would be in flat spacetime. Also, the kinds of trajectories that would allow Born rigid motions are more limited in curved spacetimes, because there will not be as many Killing vector fields (in fact most curved spacetimes have none).
  • · Replies 158 ·
  • · Replies 40 ·
  • · Replies 47 ·
  • · Replies 84 ·
  • · Replies 37 ·
