Boundary Conditions for a beam with two supports
The discussion revolves around determining the boundary conditions for a beam supported at two ends, focusing on the shear force and bending moment at specific points along the beam. Participants explore the implications of different sign conventions and the application of static equilibrium equations in the context of beam mechanics.
  • Homework-related
  • One participant states that at x=0, the shear force V=R1 and the bending moment M=0, while at x=9, V=R3 and M=0, questioning the negative sign in the provided solution.
  • Another participant suggests considering the deflections at the beam's edges and whether the supports can provide reactive moments.
  • Some participants assume that the deflection at both ends is zero but note that this does not imply the shear force is zero.
  • It is mentioned that the shear force at the ends should equal the reaction force due to point loads, with the bending moment at each end being zero.
  • A participant expresses confusion regarding the sign of the shear force at x=9, initially stating it as R2, then correcting it to R3, and questioning why it is negative in the solution.
  • Another participant emphasizes the need to write the equations of equilibrium to clarify the situation, pointing out potential confusion between R2 and R3.
  • There is a discussion about the sign convention for shear force, with some participants agreeing that the shear force is negative based on their defined conventions.
  • One participant acknowledges a misunderstanding regarding the sign convention and expresses gratitude for the clarification provided by others.
Participants express various viewpoints on the sign conventions for shear force and the implications of boundary conditions. There is no consensus on the correct interpretation of the signs, and multiple competing views remain regarding the application of static equilibrium and the resulting shear forces.
Participants highlight the importance of defining sign conventions clearly, as different conventions may lead to different interpretations of the shear force and bending moment. The discussion also reflects a reliance on static equilibrium equations, which have not been fully resolved in the context of the problem.
shogun000
I'm trying to find the boundary conditions for the beam shown in the figure.
Notation:
V= Shear force
M= Bending moment
at x=0 V=R1, M=0
at x=9 V=R3, M=0
In the solution provided at x=9 V=-R2. I don't understand why it's negative, since I took upwards as positive.
Help appreciated!
Ask yourself:
1. What are the deflections at the left and right edges of the beam?
2. Can the supports at the left an right edges offer any reactive moments to the loading of the beam?
1) I assumed the deflection at both ends is zero.
But that doesn't mean the shear is zero?
2) The supports don't seem to provide any bending moment.
1. You are correct. What happens at the ends with respect to the shear force?
2. What must the bending moment be at each end?
From what I understood in lectures, the shear force at the ends of the beam has to be equal to the reaction force going through the beam given that they are point loads.
The bending moment at each end is 0.
Correct.
That brings me back to my initial problem,
at x=9 Shear force=R2
But in the solutions it's: Shear force= -R2
I don't see why it's negative R2.
Write the equations of equilibrium and solve them. It's not clear from your attachment if you are talking about R2 (which is horizontal) or R3 (which is vertical).
Sorry my bad!
I meant:at x=9 Shear force=R3
But in the solutions it's: Shear force= -R3
I don't see why it's negative R3.
I already have the values of R2 and R3 from the question. It's just a matter of determining the shear force at the extremes of the beam.
I agree with you. The way you have it drawn, R3 should be positive, and the shear force should be positive. Why don't you provide more details on the "correct" solution that has been provided to you?
I've attached the part of the solution,
Macauly's notation is being used to formulate the equation of shear force.
You've still got to write the equations of static equilibrium for the beam and solve them for R1 and R3.
This step must be done before you can proceed with Macaulay's method or any other technique to solve the beam.
"at x=0 V=R1, M=0
at x=9 V=R3, M=0
The above quote from your #1 is stated without regard to signs. The sign conventions for shear force are not universal. What is the definition of shear force that you are using, and what is the sign convention you are adopting?
I've attached my working out.
Hope that clarifies things!
Sorry about the orientation, I can't seem to rotate it.
So, at a section say 1m from the right hand end, do you think the shear is positive or negative, according to the sign convention you have given?
I'd say the shear is positive R1 at x=1m.
Yes if x=1 m from left end. What about x=8?
Ahh! Negative R3 because the force R3 has to bring the shear to 0 at x=9.
Agreed negative but I hadn't thought of your reasoning before now. The sign convention diagram you gave us showed positive shear as "downwards to the right" of the section. But this shear force is "upwards to the right" and therefore negative. (There are other conventions in use for M and V - that's why you should state them when you use them)
at x=8 I'd say the shear force is negative R3.
Edit: replaced R2 instead of R3.
I am sure you intended to say R3. That solves your issue, I think.
Yes sort of makes sense now!
Thank you all!
