Boundary conditions for the Heat Equation
The discussion focuses on boundary conditions for the heat equation in polar coordinates, specifically using the equation $$u_t=k(u_{rr}+\frac{1}{r}u_r+\frac{1}{r^2}u_{\theta\theta})$$. The user is exploring separation of variables with the form $$u(r,\theta,t)=T(t)R(r)\Theta(\theta)$$ and is seeking guidance on implementing boundary conditions that deviate from zero temperature at the boundary. Key insights include the necessity of a zero radial temperature gradient at the origin $$\frac{\partial u}{\partial r}\Bigg|_{r=0}=0$$ and the flexibility of the outer boundary condition based on the physical scenario being modeled.
  • Understanding of the heat equation in polar coordinates
  • Familiarity with separation of variables technique
  • Knowledge of ordinary differential equations (ODEs)
  • Basic concepts of boundary value problems in mathematical physics
  • Research inhomogeneous boundary conditions for partial differential equations
  • Study the properties of Bessel functions, particularly $$J_1$$, in relation to heat equations
  • Explore the method of superposition for solving heat equations with steady-state solutions
  • Investigate physical scenarios that influence boundary conditions in thermal systems
Mathematicians, physicists, and engineers working on heat transfer problems, particularly those dealing with boundary value problems in polar coordinates.
Leonardo Machado
Hello guys.
I am studying the heat equation in polar coordinates
via separation of variables.
which gives the ODEs
$$T''+k \lambda^2 T=0$$
$$r^2R''+rR+(\lambda^2 r^2-\mu^2)R=0$$
$$\Theta''+\mu^2\Theta=0$$
but i can't properly think about the boundary conditions to this problem. I see every where people resolving it with
|u(0,\theta,t)|<\inf \mapsto |R(0)| < \inf
and
$$u(r*,\theta,t)=0 \mapsto R(r*)=0$$
being r* the border of the disc.
But i understand the radial condition as a termal bath at zero temperature and i really want to change it for a finite value but i don't know how to procede without the zeros...
Any suggestions?
The boundary conditions depend on what physical situation you wish to describe. Can you be more specific about this?
The boundary condition at r = 0 should be zero radial temperature gradient.
Time equation should be
$$ T' + k\lambda^2T = 0$$
This is correct only in the case of rotational symmetry of the problem. The general solution will contain contributions from ##J_1##, which has non-zero derivative at ##r = 0##.
You should have the inner boundary condition:
<br /> \frac{\partial u}{\partial r}\Bigg|_{r=0}=0<br />
This is the proper symmetry condition. The outer boundary condition is physics dependent however and can be absolutely anything.
I have solved it guys!
To operate with inhomogeneous bondary conditions I've used
u(r,\theta,t)=v(r,\theta,t)+u_E(r,\theta)
being u_E the steady state and "v" the solution of the heat equation.
  • · Replies 22 ·
  • · Replies 36 ·
