Bounded regions and triple integrals
tix24
a) sketch the region in the first octant bounded by the elliptic cylinder 2x^2+y^2=1 and the plane y+z=1.
b) find the volume of this solid by triple integration.
I have already sketched the elliptic cylinder and the plane. my problem arises with the triple integration.
I do not understand if i have to find the volume of the entire solid or the volume of the solid in the first quadrant.
also i am having trouble setting up the integrals because of the ellipse. i tried both cylindrical coordinates and spherical but i get stuck because of the 2.
for spherical coordinates i get stuck at the following: rho^2sin^2(phi)(2cos^2(theta)+sin^2(theta))=1
for cylindrical i get stuck here: 2r^2cos^2(theta)+r^2sin^2(theta)=1
i have also figuired the following integral out but I am not sure if it correct. i did this one in rectangular coordinates.
4(∫dx∫dy∫dz)
where the limits of integration for x are 0 to 1/√2
for y are 0 to √(1-2x^2)
for z are 0 to 1-y
can anybody comment on this?
You want to find the volume of the solid under ##z = 1 - y## and above the elliptic cylinder ##2x^2 + y^2 = 1## in the first octant, i.e ##x, y, z \geq 0##.
$$\iiint_V \space dV = \iint_R \int_0^{1-y} \space dzdA = \iint_R 1 - y \space dA$$
Now project the elliptic cylinder onto the x-y plane, this will allow you to obtain limits for ##x## and ##y##. To obtain these limits, I would suggest creating an invertible transformation between the ##(x,y)## and ##(u,v)## space and then finding the corresponding Jacobian.
i don't know how to do the transformations; owever, i have come up with the integral, the problem is i don't know how to compute it. i came up with the integral in rectangular form and it goes as follows
∫dx∫dy∫dz
for z are 0 to 1-y
also i tried to convert cylindrical and spherical coordinates but was then stuck becasue of the two, any help on how to compute this integral would be greatly appreciated.
∫dx∫dy∫dz
for z are 0 to 1-y
Your Cartesian integral looks fine, and can be handled with simple substitutions.
The reason I suggested the ##(u,v)## co-ordinate transform though is it will allow you to map the elliptic cylinder in ##(x,y)## space to a circle of radius 1 in the ##(u,v)## space. Now that you have a ##(u,v)## integral, you can apply polar co-ordinates to the circle and basically read limits off without thinking.
In case you want to try it, let ##x = \frac{1}{\sqrt{2}} u## and ##y = v##, the elliptic cylinder then maps to ##u^2 + v^2 = 1##.
how can i solve the integral with simple subsittution? if i break the integral up into 2 diferent integrals and use the sum rule, in one integral i have a square root and u substituion does not hold for this case as far as i can tell, so how would i go about solving this problem?
You have the integral:
$$\iint_R 1 - y \space dA = \int_0^{\frac{1}{\sqrt{2}}} \int_0^{\sqrt{1 - 2x^2}} 1 - y \space dydx = \int_0^{\frac{1}{\sqrt{2}}} \sqrt{1 - 2x^2} - \frac{1 - 2x^2}{2} \space dx$$
The integral of ##\sqrt{1 - 2x^2}## should remind you of a first year integral. It is of the form ##\sqrt{a^2 - y^2}## and should ring bells about trig substitutions.
