- 4,878
Fredrik said:I often say that a theory is defined by a set of axioms that tells us how to interpret some piece of mathematics as predictions about results of experiments. It sounds like you would agree.
Yes, though the axioms are not always clearly or fully spelled out. (I don't know clear axioms for the standard model.)
Fredrik said:The reason I require something more specific from a definition of "QM" is that we are already so familiar with Hilbert spaces, states, observables and so on, that we wouldn't consider a theory that uses an entirely different mathematical framework to be QM. At least I wouldn't.
The C^*-algebra approach to QM doesn't start with Hilbert spaces; in any case, it has very different axioms from the standard QM axioms, but leads to essentially the same theory.
Fredrik said:(I think of a "theory" as being defined by its axioms rather than by its predictions, because the latter choice would make "SR + there's an invisible blue giraffe that doesn't interact with matter" the same theory as SR).
Your proposal is not really cogent.
Then two versions of SR that use opposite conventions for the signature would be different theories (since the axioms differ), although they make the same predictions.
Most theories can be based on quite different axioms, depending on what you want to treat as most basic. For example, one can develop QM without mentioning state vectors in the foundations. See, e.g., the section ''Postulates for the formal core of quantum mechanics'' in Chapter A1 of my theoretical physics FAQ at http://arnold-neumaier.at/physfaq/physics-faq.html#postulates
Fredrik said:I haven't even figured out why there should be an involution.
Because we want to model standard physics, and they need complex observables
(very handy for, e.g., for describing linear circuits). Useful stuff should not be sacrificed to principles of philosophy.
So at least one should be able to have complex expectation values. And conjugation ensures that replacing i by -i doesn't change the physics!
It is very different. Without ||a^*a||=||a^||^2 you can hardly get started; the algebras not satisfying this don't resemble C^*-algebras anymore. Can't prove any spectral properties...Fredrik said:I suspect that there are no strong arguments for that identity, but I don't think is any different from why we only consider separable Hilbert spaces in the Hilbert space approach to QM.
Fredrik said:I didn't really understand your approach, or your take on the measurement problem. But I understand that you're talking about an approach that doesn't exist, or at least hasn't (yet) been developed to the point where it can be used to state the axioms of a theory that makes the same predictions as QM.
The approach outlined is fully developped though not widely publicized; it is the basis of my thermal interpretation of quantum mechanics. It agrees with how one does measurements in thermodynamics (the macroscopic part of QM (derived via statistical mechanics), and therefore explains naturally the classical properties of our quantum world. It is outlined in my slides
http://arnold-neumaier.at/ms/optslides.pdf
and described in detail in Chapter 7 of my book
Classical and Quantum Mechanics via Lie algebras
http://lanl.arxiv.org/abs/0810.1019
It is superior to the interpretions found in the literature, since it
-- acknowledges that there is only one world,
-- uses no concepts beyond what is taught in every QM course,
-- allows to derive Born's rule in the limit of a perfect von-Neumann measurement (the only case where Born's rule has empirical content),
-- applies both to single quantum objects (like the sun) and to statistical ensembles,
-- has no split between classical and quantum mechanics,
-- has no collapse (except approximately in non-isolated subsystems).
Fredrik said:One more thing: The main reason why I find the redefinition of the word "observable" discussed above acceptable, is that there's already a perfectly fine term ("self-adjoint operators") for what you want to call "observables", while nothing better than "thingamabobs" come to mind for the equivalence classes of measuring devices with finite size and accuracy. Since the idea of having something mathematical represent something in the real world is so fundamental in physics, I prefer to have good names for both the "things in the real world" and the "mathematical things", rather than two good names for the mathematical things.
Nobody in the real world thinks about "equivalence class of measuring devices" - this is not a thing in the real world, but an abstraction invented by the C^* algebra people to give meaning to their constructs, and used nowhere else.
I prefer to have two good names for the same thing, for example ''positive integer'' and ''natural number'', if these are well established in the tradition.
Errr, the only natural splitting which is allowed is by means of the natural involution dagger. There is nothing you can do here, because the operator is self-adjoint. Actually on Nevanlinna space, there is no natural algebraic criterion which gives only operators with a real spectrum. So what you propose is even bad mathematics; simply accept that your point -which any student can make- is only valid in Hilbert space.
