Break Second order ODE into a system of first order ODE's
Trenthan
I haven't done this for several years and have forgotten. Kicking myself now over it since it looks like something so simple but i cannot figure it out... I need to break this second order ODE into a system of first order ODE's in matrix form to use within a crank nicolson method.
[itex]\frac{d\Theta^{2}}{dt^{2}} + c\frac{d\Theta}{dt} + \frac{g}{L}sin(\Theta) = 0[/itex]
let
[itex]\phi_{1} = \Theta[/itex]
[itex]\frac{\phi_{1}}{dt} = \phi_{2}[/itex]
[itex]\frac{\phi_{2}}{dt} = -c\phi_{2} - \frac{g}{L}sin{\phi_{1}}[/itex]
now problem being the [itex]\sin{\phi}[/itex], how do i take the phi out! K is meant to be the coefficients of the terms infront of phi, but in this case its within the sin :S
[itex]\left[ {\begin{array}{cc}<br /> \frac{\phi_{1}}{dt} \\<br /> \frac{\phi_{2}}{dt} \\<br /> \end{array} } \right]<br /> = <br /> \left[ {\begin{array}{cc}<br /> 0 & 1 \\<br /> unknown & -c \\<br /> \end{array} } \right]<br /> <br /> <br /> \left[ {\begin{array}{cc}<br /> \phi_{1} \\<br /> \phi_{2} \\<br /> \end{array} } \right][/itex]
Cheers Trent
This is a non-linear DE, hence the difficulties
If theta was very small you could use the small angle approximation to linearise the equation
[tex]sin(\theta(t))\approx \theta(t)[/tex]
unfortunately its not, we are modelling a pendulum which is lubricated well** :(
we have been instructed to use Crank-Nicholson for some stupid reason in our design brief.
Im looking up other methods iterative techniques such as Newtons method which may be applied within the method...
Any suggestions or thoughts...?
i haven't used it but eve4rything i see on crank-nicholson is for 2d (x,t) differential equations, so not really sure how it applies here
All good
Using the Crank-Nicholson approach, and than applying Newtons law, which involves taking the jacobian etc and solving for the residue to be zero works.
Thanks for your time and help lanedance
