Breakdown Potential in a cylinder
The discussion revolves around constructing a capacitor with specific capacitance and breakdown potential requirements, utilizing a plastic drinking glass as a dielectric material. The focus is on calculating the breakdown potential given the dimensions and properties of the materials involved.
  • Participants discuss the method for calculating breakdown potential based on dielectric strength and dimensions of the capacitor. There is uncertainty about the appropriate formulas and setup for the calculations.
Some participants have provided guidance on setting up proportions to find the breakdown voltage, while others express confusion about the formulas and calculations involved. Multiple interpretations of the problem setup are being explored.
Participants are working with specific constraints, including the dielectric strength of the material and the dimensions of the capacitor. There is a noted confusion regarding the thickness of the dielectric and the conversion of units from centimeters to millimeters.
cd80187
You are asked to construct a capacitor having a capacitance near 1 nF and a breakdown potential in excess of 9000 V. You think of using the sides of a tall plastic drinking glass as a dielectric (with a dielectric constant 5.0 and dielectric strength 10 kV/mm), lining the inside and outside curved surfaces with aluminum foil to act as the plates. The glass is 18 cm tall with an inner radius of 3.64 cm and an outer radius of 3.98 cm. (a) What are the capacitance and (b) breakdown potential of this capacitor?
I have already solved part A. I used the equation C = 2 x pi x permitivity constant x (Length/ ln b/a) where b is the outer radius and a is the inner radius. However, now that I know the capacitance, I have no clue where to even start for the breakdown potential. I am also unsure of what formulas to use as well, so even just where to get started would be great.
If your dielectric has a dielectric strength of 10 kV/mm and you are using a glass that is 18cm long. Set up a proportion and solve for the breakdown voltage. Be sure to convert cm to mm.
What formula should I be using for this then? I tried just using a simple proportion, but it didn't work out
How did you set up the proportion?
btw, the dielectric thickness is 18cm right?
I set it up as 10 kV/mm = x/180mm. And the length of the cylinder is 18cm, the thickness is .34 cm.
  • · Replies 21 ·
19K
