Brine electrolysis with alluminum
The forum discussion centers on the electrolysis of sodium chloride (NaCl) using aluminum electrodes. The resulting precipitate is identified as aluminum hydroxide (Al(OH)3), which may appear gray due to the carbon coating on aluminum foil electrodes. The crystals formed after evaporation are likely sodium chloride (NaCl), as the conditions did not favor the formation of sodium hypochlorite (NaClO). The discussion emphasizes the dangers of using NaCl as an electrolyte due to chlorine gas evolution.
  • Understanding of electrolysis principles
  • Knowledge of chemical compounds, specifically aluminum hydroxide and sodium chloride
  • Familiarity with the properties of electrolytes
  • Awareness of safety concerns related to chlorine gas
  • Research the properties and applications of aluminum hydroxide (Al(OH)3)
  • Learn about the electrolysis process using different electrolytes
  • Investigate the safety protocols for handling chlorine gas during electrolysis
  • Explore the formation and uses of sodium aluminate
Chemistry enthusiasts, electrolysis practitioners, and safety professionals interested in the implications of using sodium chloride as an electrolyte in electrochemical processes.
Mniazi
I did an electrolysis with alluminum eletrodes, the electrolyte was NaCl, After completing it the left over was a gresyish precipitate (I assume aluminum hydroxide), I put most of it for evaporating in a cup, the rest evaporated leaving a jell, then later crystals. are the crystals NaCl which is covering the left over hydroxide or is it Sodium Alluminate.
Chemistry news on Phys.org
I'm sorry you are not finding help at the moment. Is there any additional information you can share with us?
Firstly, sodium can not form a compound with aluminium. They are both metals, and except for rare cases, metals do not form compounds with each other.
Secondly, the percipitate is probably Al(OH)3 like you suspected. Generally, Al(OH)3 is a fine whitish percipitate. However, if your electrodes were aluminium foil, then the carbon coating could make the percipitate look grey,
Next, depending on how long the electrolysis ran, your crystals could be NaCl or NaClO, assuming you used an undivided cell. I highly doubt you ran it long enough for there to be any appreciable amount of NaClO in the solution, and you probably would have said that it smells like bleach. So, I am assuming the crystals are NaCl.
Generally, using NaCl as an electrolyte is not a good idea due to the evolution of chlorine gas, which is VERY dangerous. If you let it go long enough in an undivided cell with NaCl electrolyte, formation of NaClO (and Cl2 gas dissolving in the solution) will turn it yellow.
So, if your solution did not turn yellowish, your crystals are probably NaCl.
Aluminates are quite common, http://en.wikipedia.org/wiki/Sodium_aluminate
In general, binary compounds (like caesium auride) are rare, but many metals are amphoteric and capable of producing salts - Al, Zn, Cr, Mn being the best known examples.
19K
  • · Replies 23 ·
9K
21K
19K
