Build Your Own Leaf Shredder with the Help of a Mechanical Engineer
  • Thread starter Thread starter czachcross
    Manual
To build a leaf shredder, it's advisable to contact the co-op linked in the discussion for plans and guidance. A mechanical engineer can assist in designing and analyzing the shredder, but for construction, a welding or fabrication shop specializing in custom equipment is recommended. The original creator of the shredder referred to himself as a "practical mechanician," which may not be a widely recognized title. Seeking help from local professionals with experience in similar projects is essential. Overall, collaboration with engineers and fabricators is key to successfully creating a leaf shredder.
czachcross
I'd like to build a leaf shredder like this:
http://dbco-op.org/dry-shredder/
I'm not a mechanical engineer and my first question is who would I ask to either make one for me or help me figure it out? Is this a tool a mechanical engineer would build?
I recommend contacting the co-op at the link you gave and see if you can get some plans for building your own.
sending out an email to them. is this a project a mechanical engineer would be involved in? If it were wood I'd call a carpenter, stone I'd call a mason but for something like this I'm not sure who to contact. The person who made the one in the video called himself a "practical mechanician." Not sure if that is a common trade name or his personal title. He doesn't live near me either.
If you were wanting to have something designed and analyzed you would use a licensed mechanical engineer. To have something like this built, you need a welding/fabrication shop, hopefully one that specializes in custom equipment (maybe farm equipment?)
ok great. thank you for the information!
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'm trying to decide what size and type of galvanized steel I need for 2 cantilever extensions. The cantilever is 5 ft. The space between the two cantilever arms is a 17 ft Gap the center 7 ft of the 17 ft Gap we'll need to Bear approximately 17,000 lb spread evenly from the front of the cantilever to the back of the cantilever over 5 ft. I will put support beams across these cantilever arms to support the load evenly
