Building a Frequency to Voltage Converter
The discussion centers on building a frequency-to-voltage converter for a three-phase 4-pole DC motor to display RPM on an LCD voltage meter. The user seeks a cost-effective alternative to a tachometer and considers using a 555 timer and LM2907 IC for the conversion. Concerns regarding input voltage levels from the motor controller, which outputs 91V pulses, are addressed, suggesting the need for voltage limiting components. The conversation emphasizes the importance of understanding the frequency-to-voltage ratio for accurate measurements.
  • Understanding of frequency-to-voltage conversion techniques
  • Familiarity with 555 timer circuits
  • Knowledge of LM2907 frequency-to-voltage converter IC
  • Basic circuit design principles, including voltage limiting components
  • Research the implementation of a 555 timer in frequency measurement applications
  • Study the specifications and applications of the LM2907 frequency-to-voltage converter IC
  • Explore circuit design for voltage limiting using resistors and diodes
  • Investigate digital frequency counter designs for improved accuracy
Electronics hobbyists, circuit designers, and engineers interested in building frequency-to-voltage converters for motor RPM measurement and related applications.
meitl
I found an old circuit diagram online but have never been able to find it again.
Here is what I am trying to do:
The three-phase DC motor I am working with is a 4-pole motor. Therefore there is a direct relationship between the frequency between the motors phase-leads, and the current RPM of the motor. IE - 2 magnetic cycles per revolution
What I need to do is take frequency measurements between the leads and convert that to a voltage that is representative of the motors RPM, which i can then display on a LCD voltage meter. I believe this to be a much cheaper method of obtaining a tachometer (plus it is an interesting project).
Interesting side-note: Using wheel radius and gear ratio I could easily output MPH using op-amps, although it would be inaccurate while the car is gliding in neutral.
If anyone has any ideas or links to a good circuit diagram it would be greatly appreciated. My background is in Physics, so my ability to design complex circuits like this is very limited without extensive research.
You can make an analog frequency-to-voltage converter with a differentiator stage, but I'd be inclined to do this project digitally instead.
The function that you are asking about is basically a "frequency counter". Check out this page and the links at the bottom to see if they are of help (especially the "building your own frequency counter" link):
http://en.wikipedia.org/wiki/Frequency_counter
The simplest approach I can think of is to use a 555 timer to generate a pulse slightly shorter than the period of your highest frequency. Pass the frequency through a Schmidt trigger so you have a clean waveform to trigger the 555. Read the output of the 555 with a digital voltmeter. The voltage may be a little erratic at the lowest frequencies.
Or alternatively, just use an f-V converter IC such as LM2907 from National Semiconductor.
Although that would not be as much fun
http://www.national.com/mpf/LM/LM2907.html
I found this circuit diagram.
http://freecircuitdiagram.com/2008/08/19/frequency-to-voltage-converter-change-your-voltmeter-to-frequency-meter/"
Will it work?
And if so how would it be implemented? I need to make a measurement between two of the phase terminals of my motor controller.
I guess I need to be more specific, the frequency I am reading comes from a MC that is outputting 91V pulses, from what I read that national semiconductor model will not like having an input voltage that high.
Correct me if I am wrong.
R1 along with D1 & D2 will limit your input voltage to +/- 0.7 volts. It'll probably still work but R1 should be at least 1/4 watt.
What is the frequency to voltage ratio you want? In other words what are the lowest and highest frequencies you expect and their corresponding voltages?
The circuit you reference is similar to what I was suggesting above but is set up to produce a 200 uS second pulse maximum. This seems a little a little short for your application. Depending on your frequency range you will probably have to increase C4 significantly.
  • · Replies 19 ·
  • · Replies 46 ·
  • · Replies 17 ·
