Building a Full-Spectrum LED Light Array for My Grow Station
47 replies · 23K views · last reply
kamko15 said:
Hey guys I havn't made a post in a while, but I have an update on this project.
I got all of the supplies I needed to complete the 70 WATT panel so I went ahead and did it
Top view of an aluminium plate holding a grid of high-power LEDs on star-shaped mounts, wired in vertical strings of seven, with small driver boards at the top and green and orange wires.
Aluminium plate mounted with rows of star-shaped high-power LED modules, wired in strings with green and orange leads, each row ending in a small black driver board on the right.
A hand reaching over a long row of wired LED modules mounted along a sheet-metal channel, with red, blue and black wires running between them and the channel edges covered in dark tape.
Looks pretty dam good you might say...WRONG!
I was really sure of my method so I wired everything up and never stopped to test, and this is what it got me.
Photo of a red LED array mounted on a flat board, with ten vertical strings of star-shaped LED modules wired together, several of them lit red and pink, with small heat sinks behind.
I think there are two duds which doesn't say much for the quality of the LEDs, but besides that the series connections don't seem to be working.
heres a few close ups of how I wired them maybe someone could give me a little insight on how to fix this.
Close-up of two star-shaped LED modules wired in series on an aluminium plate, with green and orange leads connecting to a driver marked LED DRIVE 350mA.
Photo of three rows of high-power LEDs mounted on star-shaped black heatsinks on an aluminium plate, wired in series with green and orange leads, with LED driver modules at the right end.
P.S. here is the power supply I am using maybe this has something to do with it as well.
Photo of a Mean Well CLG-150-24A LED driver label showing input 100-240VAC 2.0A, output +24V 6.3A, lead colours brown, blue and green/yellow, Io ADJ and Vo ADJ knobs, and IP65 rating.
Thanks for taking the time to report back.
I couldn't find any reference in the thread as to the wiring definition of the LEDs base terminals. (edit: oh wait. Yes there is. Let me read it first) Guessing here that the green "-" supply should be on the last LED in the string?
what's IN and what's OUT on your LED's ?
Clearly, current is only going through the first one of each string.
One of those wires from each constant current driver needs to go to LAST LED in its string...
so the current will go through all of them before returning to supply.
You had it right a couple weeks ago, , take a look at the sketch in your post of Feb1-12 11:49 PM.
Where's the wire going to last LED, that blue wire at top of panel? I thought you were showing it as 'typical " for all rows.
Looks like you hooked it to first LED instead.
Good thing you had that constant current driver in there !
Looks like your green negative supply should be on the last LED. Here's the diagram from your link, with my green and orange annotation.
Top-view dimensioned drawing of an LED package with a 7.40 width, a Ø8.00 outer diameter, and a 1.50 tab dimension; labelled Cathode Mark, with yellow plus and green minus annotations on the two leads.
  • Top-view mechanical drawing of an LED package titled Top view, showing a 7.40 width, a diameter of 8.00, a 1.50 tab dimension, a Cathode Mark label, and yellow and green handwritten annotations marking plus and minus leads.
Yeah, Thanks for the replies guys I relized my mistake only after posting. I fixed the problem and am still having troubles so I am turing again to you.
here it is all fixed up
Photo of a grid of 14 star-shaped LED modules on an aluminium plate, each string wired in series with orange and green leads to a small transformer-type driver at the top.
Close-up of a grid of star-shaped LED modules on an aluminium plate, wired in series rows with orange and green leads and driver boxes at the right edge.
The electrical tape is only temporary.
Heres is it all Lit up.
Photo of a grow-light board with about ten columns of RGB LED modules on a metal plate, lit in pink, red, blue and white under a purple glow, with a hand in the lower foreground.
Even though its not perfect yet, it still looks pretty cool. I also replaced the first two LEDs in line 10 and it is now lighting perfectly.
Problem 1- as you can see the LEDs in lines 1,2, and 8 are lighting but very dimly and I am not sure why.
Problem 2- line 9 is not lighting at all, like power isn't even reaching it.
Im not sure where these problems originate from or what could be causing them, but I need to solve these problems in order to move forward with this project. You guys have been a great help so far and I am hoping that you all have a bunch more advice to give.
P.S. It may have something to do with how the drivers are wired to the power source?:confused:
Close-up of a homemade LED array: rows of star-shaped high-power LED modules on aluminium board, each row wired to a small transformer-style driver, with red and blue and black wires running across a carpeted floor.
+1
The driver ICs have paid for themselves already! :smile: :smile:
Why have you got wires glued to the metal plate atop the ICs? (Photo is not clear.)
See all those return wires that run back beside each row of LEDs and get soldered each to a green wire? Could you have done away with all that, and instead run a single heavy-gauge wire to connect together each last LED of each row and run that straight back to the power-supply?
What is the model of the IC? Do you set the current level with a single resistor?
Are the LEDs a push fit? If one LED is sick or dead, it may affect all the others in that row. So can you swap one at a time a LED from a crook row into a good working row to see whether the fault lies with that LED? If all LEDs test OK, then you'll have to conclude that you have got the IC wrong somehow.
Kamko - do you have a el-cheapo multimeter? They're only $9.95 at Walmart, i like the little yellow GE in hardware better than the Keltec in automotive because it has one more ohms range and it's fifty cents cheaper (at my walmart anyhow).
Anyhow - Nascent is more skilled than i at posting pictures and talking you through tests...
Simple voltage readings across each LED will take you quickly to the trouble.
Probably about two volts across the ones that are lighting properly.
A single bad solder joint will make a string not light at all
One LED in backward will probably make a string dim, and so would a bad constant-current regulator.
This is how ALL projects go -
first you build it,
then you get it sort of working
then you get it working,
then you get it working GREAT !
and how we learn from our mistakes !
You're doing just fine. Where did you buy your LED's ?
old jim
Eh? I don't think I've ever posted a picture! But I'm working up to it ... :wink:
But will they all glow, even the backwards one?
+1
Didn't he give a link to the receipt from his purchase of the LEDs? (I can't open it, but nevertheless, he said it's the receipt.)
kamko15 said:
...The electrical tape is only temporary...
Nice heat shrink tubing. Always good to have around.
Hey guys, I am very appreciative of the fast and focused replies. I have received some questions from you all and will be pleased to answer all of them.
NascentOxygen, you asked
there is no metal plate, the "IC" housing is all some type of polymer plastic. the Buckpucks I am using have he option to dim. Currently I do not wish to use this feature, so I glued them on the top of the plastic Buckpuck just in case I would ever want to include a dimmer.
all those return wires that run back beside each row of LEDs and are each soldered to a green wire? Could you have done away with all that, and instead run a single heavy-gauge wire to connect together each last LED of each row and run that straight back to the power-supply?
No the drivers need to complete a series in each series of LEDs. They have a set input and output witch only allows them to power so many. If I where to use the method you described I do not think that the panel will perform the right way, or even work at all.
Im not sure what the term "IC" stands for so I am assuming your talking about the drivers.They are http://www.luxdrive.com/download/?dltf&dmid=1109. (let me know if this link doesn't work)
I'm not familiar with your terminology, please explain and I will answer best as I can.
JimHardy, Thanks for the tip about the multimeter I went out and purchased one For $21. A little pricey, but it has many functions and I am all about investing in tools. you asked where I purchased my LEDs.
Heres the invoice, all the info you may want to know is there. They arrived within a week, no damage, extremely well packaged, and shipped DHL. Let me know if your curious about anything else.
Proforma invoice from Shenzhen Justar Electronic Technology listing 100 pieces each of three LED products and a delivery fee, with unit prices and totals in US dollars.
MY MISTAKE ;;; that was Digoff - my apologies to both of you !
Thanks for the tip about the multimeter I went out and purchased one For $21. A little pricey, but it has many functions and I am all about investing in tools...
$21 wow, i guess you got a digital?
okay , time for old fashioned troubleshooting.
Set meter to DC volts
on a string that works, measure Buckpuck volts between LED + and LED -
and measure volts across each LED in that string so you get a feel for how close they match.
On a string that doesn't work, make same measurements. What's different?
What are those black & yellow wires on top of Buckpucks for? Resistor for control-ref pins?
What's value of resistor? I didnt quite see in datasheet how to use that feature... probably i just didnt look hard enough.
its late - i'll take better lok at your pictures in the morning.
Lastly i notice you have seven LED's in your rows and Buckpuck only shows six in their diagrams... they recommend input voltage be 4 volts higher than what is needed to light LED's , can you tweak that supply up a bit? Its datasheet says it'll go to 27 volts...
http://www.meanwell.com/search/CLG-150/default.htm
Subtracting that 4 volts"headroom" from 24 volt supply leaves 20, which shared by seven LED's is 2.85 volts each
but subtracting 4 from 27 leaves 23, or 3.28 volts each.
just thinking ou loud.
The sight of all those IC drivers adding their heat to your grow box makes me think we should have suggested that you house the drivers separately from the LEDs. You could perhaps use their heat underneath a sprouting tray.
Keep this in mind if you find there is too much heat for the plants under the LEDs.
The drivers do not produce any heat themselves. Do you mean they make the LEDs run hotter?
I just looked at their data sheet. They are a switching regulator, so indeed produce very little waste heat. Some of them can even be powered from AC or DC, that's neat!
No. The LEDs are being well looked after.
How are you going with the fault-finding? All working yet?
Have you been able to gauge whether your LED array will produce too much heat for good growing conditions, such that a fan is needed?
All working yet?
Indeed, keep us posted.:approve:Here's something that might be worth a try, just to rule it out:
Paragrapph "Connections" in BuckPuck datasheet suggests for DC versions a capacitor near the DC input terminals.
With high frequency stuff that's sometimes important.
Twist the + and - leads together too, that minimizes the area(and therefore inductance) of current loop to the switchers .
kamko15 something caught my eye in the second of these photos: https://www.physicsforums.com/showpost.php?p=3788447&postcount=34
Where you joined each heavy gauge orange wire to the green, the solder joint is exposed and itching to make contact with the aluminium plate. If more than one exposed joints touch the aluminium at the same time, there may be damage to the drivers, I can't say. But even if they work okay, intermittent contact like this may be a source of radio interference on nearby radios. I'm wondering why you have not insulated that joint?
Plants grow best may only use in the mixture of red and blue spectrum. And red is good for promoting the fruiting and flowering ,while blue is good for enhancing vegetative growth.
kamko15 said:
I recently began making a cabinet into a grow station. It's almost finished, but I'm having trouble with the lighting system.
Well, Kamko15, it has been 5 months since you got this going. We're waiting for a report on its success. https://www.physicsforums.com/images/icons/icon6.gif
How is your first crop of tomatoes coming along? :smile:
