Built-in voltage of pn junction diode
7 replies · 4K views
Homework Helper
Why can't the built-in voltage of diode be measured by a voltmeter when the diode is isolated? A potential difference of almost 0.7V exists at the junction, which is clearly not too small for the voltmeter to detect. What's the reason?
Because the voltage is there only when a current flows. The voltmeter won't cause a significant current flow.
It is not a voltage source like a battery.
Why does it not act like a voltage source? There are +ve and -ve charges present. Isn't it like an electric dipole?
A more precise answer is because the contact potentials at the p-metal and n-metal junctions exactly counteract the built-in potential.
That's what I read somewhere but didn't understand fully. Could you please elaborate? What exactly is the contact potential?
cnh1995 said:
That's what I read somewhere and didn't understand fully. Could you please elaborate?
Did you hear already about a Schottky diode? This a junction between metal and semiconductor - and exactly such a junction exists (necessarily) caused by the contact material at both ends of the pn diode. And the diffusion voltages at these junctions compensate the diffusion voltage across the internal pn junction.
This is a common question and has been the subject of a number of threads at Physics Forums such as
https://www.physicsforums.com/threads/pn-junction-open-conditions-conservation-of-energy.478671/
A simple graphical explanation showing why this must be true is on the first two pages here:
https://www.google.com/url?sa=t&rct...rd0cCNe0g6l2U98TPl1EMg&bvm=bv.107467506,d.cGc
The important point is that the metal part of the circuit is all at the same (0) potential, so Vbi must appear in reverse at each semiconductor contact.
