Bullet hits door, find angular velocity
6 replies · 20K views
aliaze1
Unfortunately I was absent when a similar example was done in class...
A 10 g bullet traveling at 400 m/s strikes a 10 kg, 1.0-m-wide door at the edge opposite the hinge. The bullet embeds itself in the door, causing the door to swing open.
What is the angular velocity of the door just after impact?
0.5mV^2
0.5Iω^2
v = ωr
Attempt #1:
I considered the bullet as a particle in linear motion. After collision I considered the mass of the door to be (M = Mdoor+Mbullet). I set up the problem like so:
0.5mv^2 = 0.5Iω^2
the 0.5 is a constant so it cancels..
mv^2 = Iω^2
*note* small 'm' is mass of the bullet, big 'M' is for the door, same goes for 'v' and 'V'
Then I plugged in the moment of inertia I, which is given in a table as 1/3ML^2
the width of the door is 1m, so the L^2 is simply 1
so putting this into the equation, I get:
mv^2 = (1/3M)ω^2
and rearranging and solving for ω, I get:
ω = √[(mv^2)/(1/3M)]|
(square root)
this did not work...Attempt #2:
I tried to find the linear velocity by using just conservation of linear energy
0.5mV^2 = 0.5MV^2
0.5 cancel, so it is mv^2 = MV^2 and find the linear velocity as so:
V = √((mv^2)/M)|
and then using V = ωr, I solved for ω
but still incorrect...
pic
Here is an image I made on paint, this is the way I see it, bird's eye view...
http://photo.ringo.com/210/210049338O350481129.jpg
here is the link if it doesn't come up for some reason
http://photo.ringo.com/210/210049338O350481129.jpg"
when you right 1/3M is that M/3? In any event, I think momenta is what should be conserved.
yes, this is the moment of inertia: 1/3 ML^2
but L is 1, so L^2 = 1 and therefore it is 1/3 M, or as you stated, M/3
conservation of momentum would be the way to go here.
The alternate answer is zero, because the door is locked and the latch holds
lol
door locked, nice one haha
ok ill try conservation of momentum
so do i do the bullet as linear momentum, and the door as rotational
so it would be:
mv = rMω
WOOT WOOT!
Got it!
i used conservation of momentum:
mv = Iω (found this part in the txtbook)
and I is given as 1/3ML^2 for a 'thin rod about side'
thanks!
