Bullet hitting stationary Target.
  • Thread starter Thread starter Adarshaero
    Bullet
A bullet with a mass of 0.005 kg traveling at 20 m/s penetrates a stationary target and comes to rest in 0.01 seconds. The calculated acceleration is 2000 m/s², and the distance penetrated is 30 cm. The discussion confirms that the bullet's acceleration is negative, as it decelerates while entering the target. The approach to solving the problem is validated, emphasizing the importance of considering the direction of acceleration.
  • Understanding of Newton's laws of motion
  • Basic knowledge of kinematic equations
  • Familiarity with concepts of acceleration and deceleration
  • Ability to perform calculations involving mass, velocity, and time
  • Study kinematic equations in-depth, focusing on negative acceleration scenarios
  • Explore the concept of momentum and its conservation in collisions
  • Learn about the effects of material properties on projectile penetration
  • Investigate real-world applications of ballistics in forensic science
Physics students, engineers, and professionals in ballistics or materials science who are interested in understanding the dynamics of projectiles and their interactions with stationary targets.
Adarshaero
A bullet of 0.005 kg traveling at 20m/s penetrates deeply into a fixed target and is brought to rest in 0.01 sec. The distace through which it penetrates is:
I used,
acceleration= V/t
= 20/.01
a = 2000 m/sec sq
Distace covered = Ut+0.5 at^2
= 20*0.01+0.5*2000*(o.o1)^2
S= 30cm.
Is it correct or any other solution is possible..?
The initial speed and the acceleration have opposite directions.
@willem2:
How is tat? can you please elaborate.
Does the bullet slow down or speed up as it moves through the block? So is acceleration positive or negative?
Acceleration reduces as the bullet enters the target.
so acceleration is negative...
The velocity reduces as it passes through the target. So yes, acceleration is negative (in the direction opposite to the velocity).
I understand ur point. So is the approach right? And how about answer?
The approach is fine. How about the answer? Have you calculated one with the new knowledge about the acceleration direction?
  • · Replies 40 ·
  • · Replies 17 ·
  • · Replies 20 ·
