How Does a Bungee Jumper's Energy Change During a Jump?
The problem involves a bungee jumper of mass m attached to an elastic string, exploring the energy transformations during the jump. Participants are tasked with writing the energy equation and using conservation of energy to determine the maximum descent distance after the jump.
  • Participants discuss the conversion of gravitational potential energy to kinetic energy and then to elastic potential energy as the jumper falls. There are attempts to establish a coordinate system and clarify the variables involved in the energy equations.
Some participants have made progress in formulating the energy balance equation, while others are questioning the definitions of variables and the setup of the coordinate system. There is ongoing exploration of how to express the energy conservation equation mathematically, with no explicit consensus reached on the final form.
Participants are navigating the complexities of defining variables such as the distance fallen and the stretch of the cord, as well as ensuring the correct application of energy principles. The discussion includes considerations of potential energy in the elastic string and the need for clarity in mathematical expressions.
patrickmoloney
A bungee jumper of mass m attaches a light elastic string to his foot, and the other end to railing of a bridge on which he stands. The string has natural length l_0 and modulus of elasticity \lambda. Write down the energy equation. use conservation of energy to find the maximum distance the jumper descends after stepping off the bridge.
Gravitational potential energy = mgh
Elastic Potential energy = \frac{1}{2}kx^2
Kinetic energy = \frac{1}{2}mv^2
I understand the principles of energy conversion during a bungee jump. So during the first interval, stepping of the bridge, the only force acting on the system(bungee jumper) is gravity(free fall). As the bungee jumper falls, the gravitational potential energy is converted into kinetic energy. When he reaches the point where the bungee cord begins to stretch, gravitational potential energy begins to be converted into the elastic potential energy of the cord. Eventually, all of the kinetic energy is also converted into potential energy of the cord, and he comes to rest for a short period of time.
I'm not really sure how to write this in mathematics. I can probably make thing easier by setting up a coordinate system with an origin. If I used the origin at l_0 below the bridge since that would 0 some terms in the conservation equation.
I found the relationship between the spring constant and elasticity, which is k = \frac{\lambda}{L}
The conservation of energy is PE_i + KE_i = PE_f + KE_f. I'm not really sure how to tie this all together. Do I have to model a differential equation or is it simpler than that?
I apprecitate any help,
Thanks
Putting the origin at ##l_0## below the bridge is a good idea. What does this give you for the initial energy of the system?
Your description is fine and, as you suggest, you just need to translate that into the maths.
1. Make a drawing, clearly indicating you choice of coordinate system.
2. Convert ##k = \frac{\lambda}{L}## to that system. Oops, you need k only, so: done.
3. Choose the initial and final points in time for the energy balance -- naturally ##t_i = 0## is the initial point when he/she jumps and ##t_f## is at the lowest point. (the exercise isn't about ##t##, but nevertheless.
4. Write the energy balance. What are the kinetic energies (which I guess you call ##KE_i## and ##KE_f## ?
I think I might have made some progress since the post.
Let h be the distance the jumper falls
PE_i=mgy=mgh
PE_f=mgy = mg(0) = 0
The potential energy of the elastic string is \frac{1}{2}kx^2 where x is the amount the string has stretched. At the bottom of the fall the string is stretched by an amount (h-l_0). But the cord doesn't begin to stretch until he falls a distance l_0. Therefore the final elastic potential energy is \frac{1}{2}k(h-l_0)^2 = \frac{\lambda}{2l_0}(h-l_0)^2
What is your coordinate system ? You confuse me with an x and a y -- and perhaps yourself too (if not here then later on in your curriculum)
ok so I've changed it a little bit. The initial position at the top before the jump is a distance h from the bottom when the jumper is at rest momentarily. Should I use a different variable for the length the cord stretches? I currently have it as x.
l_0 is the unstretched length of the string. Is there an easier way to coordinate this?
the initial kinetic energy is zero and the final kinetic energy zero, since he is at rest both of those times.
is the energy equation mgh = \frac{\lambda}{2l_0}(h-l_0)^2
How have you defined ##h##? Is that a constant or a variable? Don't you think you need a square somewhere?
I defined h to be the distance from the initial position to the final position at the bottom. It's a constant, the only variable of length that changes is the length of the cord, when it extends. I did forget to square the term (h-l_0)
Okay. so what next?
I need to find the maximum distance the jumper descends after steeping off the ledge. The maximum distance corresponds to the lowest point of the fall where the velocity is 0 (momentarily).
When he is standing on the top, he is at rest. Therefore his kinetic energy is zero.
When he is at the bottom, he is also at rest so the kinetic energy is also 0 (since the velocity is zero.)
That being said, we need to be careful because there is also potential energy in the string as it stretches.
Do I need to solve the differential equation mgh=\frac{\lambda}{2l_0}(h-l_0)^2
Solving the equation sounds like a good idea!
\begin{align*}<br /> mgh &amp;= \frac{\lambda}{2l_0}(h-l_0)^2 \\<br /> mgh &amp;= \frac{\lambda}{2l_0}(h^2-2hl_0+l_0^2) \\<br /> mgh &amp;= \frac{\lambda}{2l_0}h^2 - \lambda h +\frac{\lambda l_0}{2} \\<br /> \end{align*}<br />
Then I found this quadratic equation that needs to be solved using the quadratic formula
<br /> \begin{align*}<br /> \frac{\lambda}{2l_0}h^2 - h(mg+\lambda) + \frac{\lambda l_0}{2} = 0<br /> \end{align*}<br />
Is this correct so far? I ended up with
h = \frac{(mg+\lambda)l_0\pm l_0\sqrt{mg(mg+2\lambda)}}{\lambda}
This looks a little messy though so I'm not sure it's correct.
Looks right.
It is not differential.
Thanks very much for the help.
  • · Replies 17 ·
  • · Replies 28 ·
