Buoyancy of Balls A and B in a Swimming Pool
The discussion centers on the buoyant forces acting on two balls, A and B, of equal mass floating in a swimming pool. Participants debate whether the buoyant force is greater for ball A due to its larger volume or if both balls produce equal buoyant forces since they are floating. The consensus is that the correct answer is A, as the buoyant force is directly related to the volume of water displaced, which is greater for ball A. However, ambiguity in the question's wording regarding the conditions of buoyancy leads to confusion among participants.
  • Understanding of Archimedes' Principle
  • Knowledge of buoyant force calculations
  • Familiarity with the concept of displaced volume
  • Basic physics of floating objects
  • Study Archimedes' Principle in depth
  • Learn to calculate buoyant forces using the formula Fbuoyant = ρwater(Vdisplaced)g
  • Explore scenarios involving submerged versus floating objects
  • Investigate common misconceptions in buoyancy problems
Students studying physics, educators teaching buoyancy concepts, and anyone interested in understanding fluid mechanics and the principles of floating objects.
CynicalBiochemist
Balls A and B of equal mass are floating in a swimming pool, as shown below. Which will produce a greater buoyant force?
a. Ball A
b. Ball B
c. Force will be equal
d. Impossible to determine without knowing the volume of each ball
In the picture given, it is clear that ball A has a greater volume than B.
Fbuoyant=ρwater(Vwater displaced)g=ρwater(Vball)g
I attempted this problem in 2 ways and got 2 different answers (A and C)
How I got Answer A:
Ball A has larger volume so it is clear that the buoyant force is greater
How I got Answer C:
If the balls are floating, then
mg=Fbuoyant
Since both balls have the same mass, it follows that they must generate the same buoyant force since both are floating and have the same weight.
The correct answer is A.
Please help me out. I don't understand why my second approach is flawed. Thanks in advance
You do not show the picture, but I am guessing the ball is partly out of the water. The buoyant force depends on the submerged volume.
How I got Answer C:
mg=Fbuoyant
Yes.
I agree with OP. It’s C. The weight of the displaced volume of water will have to be mg.
Likes rude man and Charles Link
@CynicalBiochemist One thing the question doesn't seem to be completely clear on: Are they interested in the buoyant forces when both balls are submerged, or are they asking you to compare the buoyant forces when both are floating? ## \\ ## When they ask "Which one produces...?", they need to specify the circumstances they want you to consider, or the question is very ambiguous.
"Balls A and B of equal mass are floating in a swimming pool".
Me too. But all you need is buoyancy force = mg. Sure, that force is also equal to the weight of the water displaced (Archimedes).
But the question says, "Which will produce a greater buoyant force?", and not " Which is producing a greater buoyant force?". They really would do well to clarify what are they asking the respondent to answer.
Not sure I appreciate the difference but then I only got about 3 hrs sleep last night! :smile:
Likes Charles Link
The use of "will" implies a future behaviour rather than the present one, so under some other condition that needs to be specified; e.g., when pushed below the surface.
If the question has been stated exactly, word for word, in post #1 (@CynicalBiochemist, please confirm) then the omission of such a condition suggests it intends the present. On the other hand, the official answer suggests a changed circumstance.
Likes Charles Link
I can't see how you can consider changed circumstances, when the changed circumstances are not stated.
Perhaps they will be taken out of the water altogether.
We're trying to make sense out of what appears to be an incorrect answer that was supplied to the question. It appears they may have wanted the student to work a different problem than what they actually stated.
  • · Replies 17 ·
  • · Replies 31 ·
