C++ Program Help: Get Sum of N Numbers w/ Pointers
  • Context: C/C++
  • Thread starter Thread starter k_phanichandra
    C++ Program
The discussion focuses on a C++ program to calculate the sum of N numbers using pointers. The provided function, sum(type* p, int n), initializes a sum variable to zero and iterates through the array pointed to by p, adding each element to the sum. This method efficiently utilizes pointer arithmetic to access array elements. The solution is confirmed as effective for summing a list of numbers in C++.
  • C++ programming fundamentals
  • Understanding of pointers and memory management
  • Basic knowledge of arrays in C++
  • Familiarity with function syntax in C++
  • Explore C++ pointer arithmetic in-depth
  • Learn about dynamic memory allocation in C++
  • Investigate C++ standard library functions for array manipulation
  • Study performance implications of using pointers versus references in C++
C++ developers, computer science students, and anyone looking to enhance their understanding of pointers and array manipulation in C++ programming.
k_phanichandra
What is the program code in c++ to get the sum of given n numbers using pointers?
Technology news on Phys.org
"using pointers" is vague, also there is a separate programming forum...
if you have a list of length n and some pointer p to the start of that list, of the correct type then:
Code:
type sum(type* p, int n)
  type sum = 0;
  for(int i = 0; i < n; i++) sum += p[i];
  return sum;
is a function that sums the numbers
Thanks for giving an answer to my question.
  • · Replies 17 ·
  • · Replies 40 ·
  • · Replies 118 ·
10K
  • · Replies 19 ·
  • · Replies 25 ·
