Cal3 cyliderical spherical coords
  • Thread starter Thread starter Eunix1992
    Spherical
The discussion focuses on calculating the volume between the cone defined by the equation z = √(x² + y²) and the plane z = 14 + x, above the disk x² + y² ≤ 1. Participants emphasize the importance of consistently using either Cartesian or cylindrical coordinates to avoid confusion. The cone's equation should be expressed as z = f(r) and the plane as z = g(r, θ) in polar coordinates, where the height of the volume is determined by the difference between these two functions. The integration limits are established as 0 ≤ r ≤ 1 and 0 ≤ θ ≤ 2π.
  • Understanding of cylindrical coordinates and their application in volume calculations
  • Familiarity with polar coordinates and their conversion from Cartesian coordinates
  • Knowledge of integration techniques in multivariable calculus
  • Ability to manipulate and interpret equations of cones and planes in three-dimensional space
  • Study the conversion of Cartesian coordinates to polar coordinates in detail
  • Learn about the use of infinitesimal volume elements in cylindrical coordinates
  • Practice setting up and solving triple integrals for volume calculations
  • Explore examples of calculating volumes between surfaces using different coordinate systems
Students and educators in calculus, particularly those focusing on multivariable integration, as well as anyone involved in geometric applications of calculus in engineering or physics.
Eunix1992
find the volume between the cone z=√(x^2+y^2), and the plane z=14+x, above the disk x^2+y^2≤1, for the exact number
r^2=x^2+y^2;
I found x=z, for x^2+y^2≤1, for solve r^2≤1, so r≤1, or r≥-1. for θ,from0 to 2pi, but I don't know what range for z, and what equation I shoud use for f(x,y), just √(x^2+y^2)?
thanks.
I think you are going to need to come down firmly on the side of working with either Cartesian or cylindrical coordinates, because this mixture of systems is creating unnecessary confusion.
You have an "apex-down" cone (the apex at ( 0, 0 ) ) opening "upward" in the positive z-direction being intersected by an oblique plane. You will find it easier to deal with this if you express the cone as z = f(r) (which will be the "floor" of your volume) and z = g( r, theta ) [what is 14 + x in polar coordinates?] (which is the "ceiling" of your volume).
You can now get an integrand function for the "height" of the volume as a function of r and theta . You will be integrating over 0 ≤ r ≤ 1 and you have the correct interval for theta. Be sure to use the infinitesimal volume elements for cylindrical coordinates. This will not be too hard to set up (it's a bit more work to actually integrate...).
thanks.
but i still not understand the range for z, and that function i should use for f(x,y)which be intefrated. thanks.
I mean for z I used 14+x, and r; for r, I used 0 and 1; for theta, i use 0 and 2pi? if those are all correct, how can i get exact number? i should have x in final answer. Thanks
In polar coordinates (which are two of the three coordinates in the cylindrical system),
z = 14 + r \cos \theta . So the height of the enclosed volume is (14 + r \cos \theta ) - r , since the equation for the nappe of the cone above the xy-plane is just z = r .
  • · Replies 26 ·
  • · Replies 21 ·
