Calc3 vectors, lenght of curve, equation of the sphere.
The discussion revolves around vector analysis, parametric equations, and the geometry of spheres in a three-dimensional space. Participants are exploring vector components, curve lengths, and sphere equations in the context of calculus.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants are attempting to define vector U from points A and B, questioning the terminology used in the original post. There are inquiries about the nature of the parametric equations and how to find the length of the curve. The equation of the sphere and its relationship to the xy-plane is also under discussion, with some participants questioning the radius calculation.
Some participants have provided insights into the calculations needed for the length of the curve and the properties of the sphere. There is a mix of attempts to clarify concepts and check work, with no explicit consensus reached on the solutions.
Participants are navigating through potential misunderstandings regarding terminology and mathematical expressions, with some constraints related to homework guidelines and the need for clarity in problem statements.
pillar
1.Consider the process A[1,1] and B [-1,4]; let Vector U=AB
1a.Write u using components. Write u using the standard basis.
1b.Draw u as a position vector. Find u.
1c.If C [1,1] and D [5,y], then find the value of y so that AB is parallel to CD.
2. Find the length of the curve 2t2 3t2 , 0<t<[3/4]
3. Find the equation of the sphere with center [2,3,4] and is tangent to thee xyplane. At what points does the sphere intersect the z axis?
2.distance formula
3.
My Answers
1a. -1-1=-2 4-1=3 u=<-2,3> u=<1,1> <-1,4>
1b. u=-22+32[1/2] =131/2
1c. [5-1/2],[y-1/2] [2,y-1/2]
2. [PLAIN]http://img255.imageshack.us/img255/9178/hillo1.png
3.[PLAIN]http://img408.imageshack.us/img408/9339/hillo2.png
This doesn't make any sense to me. What is a "process"? What sort of multiplication is done with AB?
Are these the parametric equations for the curve?
2.distance formula
3.
My Answers
The radius of this sphere is not sqrt(29).
AB is a Vector.
Yes those are parametric equations for the curve.
I don't know how to solve 3, I need some help.
When does a position function hit the z axis? When the y and x-axis are 0.
pillar said:
bump
It is against forum policy to "bump" a thread and can get you banned.
If x= x(t) and y= y(t) then the arclength is given by
[tex]\int\sqrt{(x'(t))^2+ (y'(t))^2} dt[/tex]
not
[tex]\int\sqrt{(x(t))^2+ (y(t))^2} dt[/tex]
which is what you seem to be trying.
For [itex]x= 2t^2[/itex], [itex]y= 3t^2[/itex] that would be
[tex]\int\sqrt{4t^2+ 36t^2}dt= 2\sqrt{10}\int t dt[/tex]
not what you have.
3: If a sphere has center (a, b, c) and is "tangent to the xy-plane" then the radius to that plane is perpendicular to it. That means that the radius of the sphere is "c".
Sorry about the bump, thanks for checking my work.
