Frostman
- 114
- 17
- Homework Statement
- In an inertial reference system S, we have a photon with spatial components only along the x axis, its quadrimoment is ##p = E (1, 1, 0, 0)##. There is a special class of Lorentz transformations, called "small group of ##p##", which leaves the components of ##p## unchanged. For example, any rotation around the x axis belongs to this class.
a) Calculate a sequence of boosts and rotations whose product belongs to the small group of p, but which is not a simple rotation around the x axis. To do this, follow the suggestions below.
I) Apply a generic boost in the y-z plane (take advantage of the arbitrariness in deciding the alignment of the y and z axes).
II) Make an appropriate rotation that realigns the photon moment along the abscissa axis.
III) Determine a new boost that brings the photon back to having the initial components.
b) Write explicitly the Lorentz transformation found and verify that it is not a pure rotation.
- Relevant Equations
- \begin{equation*}
B =
\begin{pmatrix}
\gamma & -\gamma v_x & -\gamma v_y & -\gamma v_z \\
-\gamma v_x & \frac{v_x^2(\gamma - 1)}{|v|^2}+1 & \frac{v_xv_y(\gamma -1)}{|v|^2} & \frac{v_xv_z(\gamma -1)}{|v|^2} \\
-\gamma v_y & \frac{v_xv_y(\gamma -1)}{|v|^2} & \frac{v_y^2(\gamma - 1)}{|v|^2}+1 & \frac{v_yv_z(\gamma -1)}{|v|^2}\\
-\gamma v_z & \frac{v_xv_z(\gamma -1)}{|v|^2} & \frac{v_yv_z(\gamma -1)}{|v|^2} & \frac{v_z^2(\gamma - 1)}{|v|^2}+1
\end{pmatrix}
\end{equation*}
Let's begin with the first point.
a.I) Apply a generic boost in the y-z plane (take advantage of the arbitrariness in deciding the alignment of the y and z axes).
\begin{equation*}
B_{yz} =
\begin{pmatrix}
\gamma & 0 & -\gamma v_y & -\gamma v_z \\
0 & 1 & 0 & 0 \\
-\gamma v_y & 0 & \frac{v_y^2(\gamma - 1)}{|v|^2}+1 & \frac{v_yv_z(\gamma -1)}{|v|^2}\\
-\gamma v_z & 0 & \frac{v_yv_z(\gamma -1)}{|v|^2} & \frac{v_z^2(\gamma - 1)}{|v|^2}+1
\end{pmatrix}
\end{equation*}
I thought that for a generic boost in the yz plane we can consider a boost along the velocity vector ##v=(0, v_y, v_z)##
Applying to our moment vector we have the following result
B_{yz} p = E
\begin{pmatrix}
\gamma \\
1\\
-\gamma v_y \\
-\gamma v_z
\end{pmatrix}
a.II) Make an appropriate rotation that realigns the photon moment along the abscissa axis.
Now to realign the moment to the x-axis I have to reset the components ## p_y ## and ## p_z ## with a rotation. But with ##R_x## or ##R_y## or ##R_z## I can't find a right rotation that can make ## p_y = p_z = 0##. How I can find this rotation? Thanks for the help!
\begin{equation*}
B_{yz} =
\begin{pmatrix}
0 & 1 & 0 & 0 \\
\end{pmatrix}
\end{equation*}
B_{yz} p = E
\begin{pmatrix}
\gamma \\
1\\
-\gamma v_y \\
-\gamma v_z
\end{pmatrix}
