Calculate acceleration of a ship fired from a cannon
The problem involves calculating the acceleration of a fictional spaceship, the Columbiad, which is launched from a cannon with an initial speed of 12,000 yards/s over a distance of 700 ft. The context is derived from Jules Verne's novel, and the participants are tasked with estimating the acceleration experienced by the occupants during launch.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the initial and final velocities, questioning whether the initial velocity should be considered as zero or the given speed. There is also confusion regarding the final velocity after the acceleration distance and the implications of uniform acceleration.
The discussion is ongoing, with participants providing insights on the assumptions regarding initial and final velocities. Some have attempted calculations but encountered issues with unit conversions and formula application. There is a recognition of the fictional context, which influences the interpretation of the problem.
Participants note the fictional nature of the scenario, which may affect the assumptions made about physics principles. There is also mention of unit conversion challenges and the need for clarity on the parameters involved in the calculations.
hgducharme
Jules Verne [/B]In his novel From the Earth to the Moon (1866), Jules Verne describes a spaceship that is blasted out of a cannon, called the Columbiad, with a speed of 12,000 yards/s. The Columbiad is 900 ft long, but part of it is packed with powder, so the spaceship accelerates over a distance of only 700 ft. Estimate the acceleration experienced by the occupants of the spaceship during launch.
v0 = 10,975.60976 m/s
a = ?
d = 213.4146341 m
[/B]
1) [itex]x= x_0+v_0t+\frac{1}{2}at^2[/itex]
2) [itex]v^2 = v_o^2 + 2a\Delta x[/itex]
I tried solving the second equation, but I got an insane number that isn't plausible. My main problem is what should I consider V0, is it 0 or is it the 10,975 m/s? If I set it to 0, then I'm only calculating the acceleration from at rest to as soon as it leaves the cannon's barrel. Otherwise, if I set it to the 10,975 m/s, then I don't know the final velocity after accelerating for 213.4 m. Also, would the acceleration be considered as [itex]-9.8\frac{m}{s^2}[/itex]?
The initial velocity is zero, the final velocity 12,000 yards/s. The distance over which the capsule accelerates is 700 ft.
Remember, this is fiction...
initial speed before the charge is lit is zero
final speed you know
distance over which it accelerates is given
find acceleration (the assumption is that acceleration is uniform)
Haha, yes I picked up on that. They would have the speed to get past LEO after 213m.
So are you saying the final velocity is 12,000 yards/s AFTER the 213m uniformed acceleration?
Yes, of course. That's how canon's work. The acceleration takes place while the projectile is within the barrel.
Ok, I still can't seem to figure out what I'm doing wrong. Here's my work:
[itex]v^2 = v_0^2 + 2a\Delta x[/itex] Solving for [itex]a[/itex] gives me:
[itex]\frac{v^2 - v_0^2}{2\Delta x} = a[/itex] Plug in my values:
[itex]\frac{(12,000 yds/s)^2}{2(233.34 yds)} = a[/itex] Simplify:
[itex]\frac{144,000 yds/s}{466.67 yds} = a[/itex]
[itex]308.57 s = a[/itex]
Some how I end up with only seconds as my unit. I assume I'm using the wrong formula?
Edit: Ahhhhh, nevermind. I forgot to square my units in the numerator!
##\left(\frac{yd}{s}\right)^2 = \frac{yd^2}{s^2}## right?
And check the order of magnitude for your yards squared. You've lost several.
Yes, I just caught that, thank you
  • · Replies 16 ·
