Calculate acceleration of the 4 kilogram block
1 reply · 3K views
sobek
Three blocks of masses 1.0, 2.0, and 4.0 kilograms are connected by mass less strings, one of which passes over a frictionless pulley of negligible mass, as shown above. Calculate each of the following.
a. The acceleration of the 4 kilogram block
b. The tension in the string supporting the 4 kilogram block
c. The tension in the string connected to the l kilogram block
(Sorry but I can't seem to get the pic on here- basically on one side of the pulley is a 4kg mass, and on the other side is a 2kg mass that is connected by a string to a 1kg mass)
I don't really know where or how to start. I know I'll need to use Newton's Second Law. But I'm have difficult applying it to these problems.
Thank you
Three masses are connected by two stings.
All the masses move with the same acceleration.
Let tension in the string connecting 4 kg and 3 kg be T1, and tension in the string connecting 2 kg and 1 kg be T2.
For 4 kg, 4*g - T1 = 4*a.
Similarly write the other two equations for 2 kg and 1 kg. Then solve the equations to find T1, T2 and a.
