Calculate average power in one cycle.
yungman
This is part of a bigger problem, I simplify to just:
P=k sin^2 \omega t
How do I integrate over one cycle?
\left\langle P \right\rangle = \int_0^T k\; sin^2 (\omega t) d t \;\hbox { where }\; T= \frac c f = \frac {2\pi}{ \omega}
\left\langle P \right\rangle = k \int_0^{ \frac {2\pi}{ \omega}} sin^2 (\omega t) d t = \frac 1 {\omega} \int sin^2 u du = \frac k 2 u = \frac k 2 t|_0^{\frac {2\pi}{ \omega}} = \frac {k\pi}{\omega}
I know the answer is
\left\langle P \right\rangle = \frac k 2
Please show me how to get the integration over one cycle.
Thanks
Alan
The average of f(x) of period T: <f(x)> = \frac{1}{T}\int ^{r+T} _r f(x)dx with r is arbitrarily chosen :smile:
Another way to deal with your particular function is:
P = ksin^2wt = \frac{k}{2}(1-cos2wt)
P=k sin^2 \omega t
Thanks
Alan
Your answer of kT/2 makes more sense. Wouldn't you expect the integral (area under the curve) to be proportional to T? The only issue is whether you should be integrating from 0 to T/2 rather than 0 to T, because sin^2 has double the frequency of sine, as pointed out by hikaru's trig identity. But, if you want to integrate over the period T for the unsquared sinewave, then you are correct.
EDIT: Oh wait ! You want the average power, so you have to divide by T. That's what the issue is. So k/2 is correct.
Thanks, I forgot the 1/T.
Alan
##|\Psi|^2=\frac{1}{\sqrt{\pi b^2}}\exp(\frac{-(x-x_0)^2}{b^2}).## ##\braket{x}=\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dx\,x\exp(-\frac{(x-x_0)^2}{b^2}).## ##y=x-x_0 \quad x=y+x_0 \quad dy=dx.## The boundaries remain infinite, I believe. ##\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dy(y+x_0)\exp(\frac{-y^2}{b^2}).## ##\frac{2}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,y\exp(\frac{-y^2}{b^2})+\frac{2x_0}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,\exp(-\frac{y^2}{b^2}).## I then resolved the two...
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
