Calculate distribution of mass
  • Thread starter Thread starter Mikey-D
    Distribution Mass
The discussion centers on calculating the distribution of mass at multiple support points for an object, specifically a box, held at four or more planar points. It is established that while three support points allow for calculations using equilibrium equations (sum of forces and torques), the challenge lies in extending this to more than three points, which may create an overdetermined system. The method of sections is suggested as a potential approach, requiring knowledge of the entire mass distribution rather than just the center of mass. This indicates a need for a deeper understanding of static equilibrium in engineering contexts.
  • Static equilibrium principles
  • Method of sections in mechanics
  • Understanding of mass distribution
  • Equations of equilibrium (sum of forces and torques)
  • Research the method of sections in structural analysis
  • Study static equilibrium equations in detail
  • Explore mass distribution calculations in engineering mechanics
  • Investigate overdetermined systems and their solutions
Engineers, physics students, and anyone involved in structural analysis or mechanics who needs to understand mass distribution in static systems.
Mikey-D
I asked a similar question a while back, but am still unclear on something.
If I have some arbitrary object (a box, for instance) with known centre of mass that is held up at four (or more) planar points, is it possible to calculate exactly what portion of the mass of the box is at each of the points?
I know it can be done with three points (using three equations: sum of forces, and both components of the sum of torques about an arbitrary point), but am unsure whether it is even possible with more than three points. Seems to me it must be possible to calculate, but my searching has turned up nothing thus far.
Can anyone point me in the right direction here??
Thanks a lot!
Edit: Assume zero elasticity in the supports and object.
Try engineering. I think that is what they call an overdetermined system. The method of sections might help; essentially, cut the object at some point conceptually into two objects. Work out the equilibrium equations for each separately. I believe you need to know more than the center of mass position, which is just one summary term; I think you need the entire mass distribution. More details I do not have off the top of my head. Good luck.
In sci-fi when an author is talking about space travellers or describing the movement of galaxies they will say something like “movement in space only means anything in relation to another object”. Examples of this would be, a space ship moving away from earth at 100 km/s, or 2 galaxies moving towards each other at one light year per century. I think it would make it easier to describe movement in space if we had three axis that we all agree on and we used 0 km/s relative to the speed of...
  • · Replies 32 ·
  • · Replies 17 ·
  • · Replies 86 ·
