Calculate Internal Angular Momentum and Energy
The discussion revolves around calculating the internal angular momentum and energy of four particles, each with a mass of 1 kg, moving on a plane. The center of mass (CoM) position and velocity were correctly determined as Xcm=7/4(i + j) and Vcm= ½i + ¼j, respectively. However, there is confusion regarding the internal kinetic energy calculation, with the initial result of 23.5 J being incorrect; the correct value should be 22.9 J. Participants emphasize the importance of calculating the velocities of the particles relative to the CoM to accurately determine internal kinetic energy. The formula for the relative velocity is confirmed as V' = Vcartesian - VCoM, which is essential for the calculations.
Nicolas Gallardo
Four particles of mass 1 Kg each, are moving on a plane with the velocities given in the figure.
First I calculated the position of the CoM:
Xcm=7/4(i + j)
Then I calculated the velocity of the CoM:
Vcm= ½i + ¼j
For the internal energy I did the following:
Kint= (1/2)(1.52) + (1/2)(1.32) + (1/2)(1.32) + (1/2)(1.22) = 23,5J
But the answer is 22,9 J. And for the internal angular momentum I do not actually know with respect to which point I should calculate it. Any hint would be appreciated. Thank you.
Nicolas Gallardo said:
Xcm=7/4(i + j)
Vcm= ½i + ¼j
The numbers in the figure are hard to read. If I'm reading them correctly, it appears that your results for the position and velocity of the center of mass are correct. But, it doesn't appear to me that your values for the "internal" speeds of the particles are correct. For example, how did you get 1.5 m/s for the speed that you used in the first term of Kint? To which particle does this refer?
That is (1/2)(mv^2)⇒ (1/2)(1(5^2)). One of the velocities is 5 m/s.
The other 3 velocities are: 3 m/s, 3 m/s, 2m/s
5 m/s is the speed of the particle relative to the reference frame of the Cartesian axes shown in the picture. You would use 5 m/s if you wanted the kinetic energy of the particle relative to this frame. But, you are looking for the "internal kinetic energy". This would be the kinetic energy relative to what frame of reference?
Relative to the CoM? But how would that change in the equation?
Yes
Can you find the velocity of each particle relative to the CoM frame?
TSny said:
Yes
If we denote V' to the velocity of the particle related to the CoM frame, V to the velocity of the particle related to the cartesian axe and VCoM to the velocity of the CoM, then the velocity of the particle would be:
V'= Vcartesian - VCoM
Am I correct?
Am I correct?
Yes.
