Calculate movement of steel in magnetic field
The discussion focuses on calculating the force required to move a steel plate in a magnetic field generated by a stationary permanent magnet. Key factors include the dimensions of the steel plate, its permeability, and the magnetic field strength (B). The conversation highlights that the force required to move the steel plate horizontally is less than that required to move it vertically, due to the distribution of energy and the formation of eddy currents when the steel moves through a changing magnetic field. Understanding these dynamics is crucial for accurate calculations in practical applications.
  • Understanding of magnetic field strength (B) and its measurement
  • Knowledge of material permeability, particularly for different steel alloys
  • Familiarity with the concept of eddy currents in conductive materials
  • Basic principles of magnetism and force calculations in physics
  • Research the effects of eddy currents on the motion of conductive materials in magnetic fields
  • Explore the relationship between magnetic field strength and distance from a permanent magnet
  • Study the properties of various steel alloys, focusing on their magnetic permeability
  • Learn about force calculations involving magnetic fields and moving conductive objects
Engineers, physicists, and students involved in projects related to magnetism, material science, and mechanical design will benefit from this discussion.
jinnkraft
Hi
A steel plate with dimensions a * b and thickness t is moving in a magnetic field of stationary permanent magnet. the movement of steel plate is parallel to the magnet field. One pole of the magnet is perpendicular to the axis of steel movement. what force will be required to move this steel plate in the magnetic field 'B'. let he distance between the magnet and steel be 'd'
thanks
noor
jinnkraft said:
Hi
thanks
noor
Welcome to the PF.
Is this for schoolwork? What is the context of the question?
What kind of steel? Different alloys have different magnetization properties. SS 304 is pretty much nonmagnetic.
Low carbon steel. it has very good magnetic property.
I want to analyse the force required to move a steel plate in magnetic field for a project.
Take a look at this
http://www.codecogs.com/library/physics/magnetism/magnetic-pull-force.php
You will need to know the magnetic field strength B at a distance from your magnet. If your metal plate is small compared to the distance to the magnet, then maybe you can approximate B as constant across the metal. Otherwise, it will get more complicated. Anyways, you might be able to get a gross estimate by assuming B is constant.
You need to know the permeability of the steel. This can vary a lot between alloys and tempering. http://en.wikipedia.org/wiki/Permeability_(electromagnetism) has a table of some permeability values of some materials. You see "Ferritic stainless steel (annealed)" is given as 1000-1800.
Then you can calculate the force on the metal, which will tell you the acceleration of it.
Khashishi said:
Take a look at this
hi,
thanks for your reply.
the link has to do with electromagnets and the problem is very different.
i know the magnetic field strength B. the steel is fairly bigger than the permanent magnet.
there are two cases here.
case1. steel is stationary at a distance d from the pole of magnet. i know the force with which the steel is pulled by magnet acting Normaly.
steel can be moved in two directions.
one, the steel is moved away from the magnet perpendiculary
or , steel is moved horizontally.
how to calculate the force acting on steel when it is moved
Hi
I'd put the problem differently.
A permanent magnet of known dimension and magnetic field strength B is fixed. A steel plate of known dimension and thickness and permeability is placed at a distance d, such that the pole of the PM faces the flat surface of steel. The force acting due to PM on steel is known.
Now, if the steel plate is moved horizontally, i.e. parallel to the pole, then i'd like to calculate the force required to move the steel plate, ignoring friction.
If the steel is moving much slower than the speed of light and the steel is not charged, I don't think the motion of the plate will make any difference to the force.
thanks for your anwer
suppose the force on steel due to magnet kept below it at a distance of 1 cm is 20 N. and if this steel is moved horizontally just to be outside its magnetic field, then the force required, to move it disregarding friction, should be atleast 20 N.
But it is observed that moving steel horizontally takes less force but towards the edge compared to moving it up along the axis.
i have seen some links that say the energy gets distributed while moving steel parallel to the magnet, but there is no formula to support this.
can you share some details on this
regards
Hmm, I guess I missed an effect in my last post. If the steel is moving through a changing magnetic field, then there will be eddy currents formed in the steel which create some resistance to the motion. There will be more resistance in directions that change the magnetic field more.
  • · Replies 16 ·
  • · Replies 21 ·
  • · Replies 27 ·
  • · Replies 42 ·
