Calculate Nonconservative Work on 75kg Surfer: 0.951375 kJ
  • Thread starter Thread starter marcia888
    Work
The calculation of nonconservative work for a 75 kg surfer involves determining the changes in kinetic and potential energy. The correct formula is ΔK + ΔU = W_nonconservative, where ΔK is the change in kinetic energy and ΔU is the change in potential energy. The surfer's initial speed is 1.3 m/s, final speed is 8.2 m/s, and he drops through a height of 2.05 m. The correct nonconservative work done on the surfer is positive, specifically calculated as 0.951375 kJ.
  • Understanding of kinetic energy (KE) and potential energy (PE) concepts
  • Familiarity with the equations for kinetic energy: KE = 1/2 mv²
  • Knowledge of gravitational potential energy: PE = mgh
  • Ability to perform unit conversions between joules and kilojoules
  • Review the principles of energy conservation in mechanical systems
  • Learn about the distinction between conservative and nonconservative forces
  • Practice calculations involving energy transformations in physics problems
  • Explore the implications of external work on system energy
Physics students, educators, and anyone interested in understanding energy dynamics in mechanical systems, particularly in scenarios involving work and energy transformations.
marcia888
7. [Walker2 8.P.026.] Catching a wave, a 75 kg surfer starts with a speed of 1.3 m/s, drops through a height of 2.05 m, and ends with a speed of 8.2 m/s. How much nonconservative work was done on the surfer?
I used delta K + delta U is nonconservative force.
They want kJ instead of J.
I got -0.951375 kJ
but it tells me I'm wrong. I only have one more try. Could it be this number but positive?
I got -0.951375 kJ
you may have made a mistake with the sign of "2.05m."
the change in potential energy is
mg h_final - mg h_initial
or, factoring...
mg (h_fin - h_in)
now, the surfer DROPS that given height. so his final position is LOWER than his initial position!
taking h_fin to be where h=0, you get...
delta PE = m*g*(-2.05m)
and, of course, that 8m/s speed is the final velocity, while the 1m/s speed is the initial.
this should give you the right answer. :wink:
an intuitive way to get the sign correct is to think whether the external work added or took away from the systems energy. one way to determine this is to compare this situation to one where there is no external work.
(of course, this requires you to choose which new parameter you need to solve for. for instance, if you decide to keep the values given for inital velocity and height, the value of the final velocity will tell you whether the energy was diminished or increased. if the final velocity was lower without the external work, then the external work increased the energy and should be positive, etc.)
Since the speed of the surfer is greater after the reaction, it is clear that his energy has increased. Some of the increase is due to gravity and some is due to the waves. It's certainly possible that the waves actually did negative work on him, they could have slowed him down a little bit during the reaction. So the answer is not neccesarily positive. But it turns out that the waves did actually do positive work.
m = mass
v_{1} = initial speed
v_{2} = final speed
h = height
g = acceleration due to gravity
The conservative work done is the gravitational work done, all other work is nonconservative, so:
Total Work Done - Gravitational Work Done = Nonconservative Work Done
To find the Total Work Done, you take the difference of the kinetic energies before and after.
Total Work Done:
= \frac{1}{2}mv_{2}^{2} - \frac{1}{2}mv_{1}^{2}
= \frac{1}{2}m(v_{2}^{2} - v_{1}^{2})
Now from the Total Work Done, you subtract the Gravitational Work Done, which is equal to the Gravitational Potential Energy an object has when it is 2.05m off the ground.
Gravitational Potential Energy for 2.05m = Gravitational Work Done = Conservative Work Done = mgh
Total Work Done - Conservative Work Done = Total Nonconservative Work Done
= \frac{1}{2}m(v_{2}^{2} - v_{1}^{2}) - mgh
= m(\frac{v_{2}^{2} - v_{1}^{2}}{2} - gh)
I get a positive value > 10kJ
That help at all?
m = mass
v_{2} = final speed
h = height
Total Work Done:
That help at all?
the answer is positive, but it was the positive of the answer he had given!
the correct formula is, as he listed:
change in Kinetic Energy + change in Potential Energy = external (or nonconservative) Work
the textbook he probably uses is by serway and faughn, college physics; that's the precise equation they have in there for this!
That should give you the net work done on the surfer by nonconservative forces. Show what you got for \Delta K and \Delta U. (The change in K is positive, but the change in U is negative.)
I got -0.951375 kJ
Actually, yes. But how did you get a negative sign? (Remember that \Delta X = X_{final} - X_{initial}.)
The formula I used is the same thing.
Change in kinetic energy (KE after - KE before) plus the change in potential energy (-mgh)
I got 950kJ however, not .950 kJ
Can you see where I made an error?
(Btw on a different note, don't you think it's a little stupid to have a formula which really just says "Any change in energy from outside of the system is nonconservative"? Seems to me there is a better way to express it then have students memorize that \Delta{K} + \Delta{U} = Nonconservative work.)
Your formula is OK. Check your arithmetic.
Yeah I actually got 950 J, but in my sleepless state I decided that kg \frac{m^{2}}{s^{2}} was kJ when it is, of course, just J
Is it possible to define a conservative system as one whose potential energy is a function of only position coordinates (q), and a nonconservative system as one whose potential energy is a function of position coordinates (q) and time (t), that is,
V=V(q) for conservative & V=V(q,t) for nonconservative ?
11K
  • · Replies 23 ·
