"Calculate Resultant Force on Vertical Dam Wall
  • Thread starter Thread starter etothey
    Fluids Pressure
To calculate the resultant force on a vertical dam wall, the pressure varies with depth, necessitating integration for an accurate solution. The initial approach used a uniform pressure assumption, which is incorrect due to the changing pressure with depth. The correct method involves integrating the pressure equation from the surface to the height H of the water. This results in the pressure at the base being expressed as P = PaH + (pgH^2)/2. The final force on the dam wall is then calculated as F = HW(PaH + (pgH^2)/2).
etothey
Pressure_2.jpg: http://www.imageupload.org/thumb/thumb_8609.jpg
A vertical dam wall has a width w. Water is filled to a height H behind the dam. Calculate the resultant force on the dam wall.
P=F/A
P= Pa + p*g*h
Using picture to solve the question
P=F/A
A=H*W
Thus P=Pa g*h*p where p is density and P is pressure.
Thus F=P*A=H*W*(Pa + gHp) where g is gravity.
Is this correct?
Your solution, as I've understood it, would work if the pressure were uniform, that is, constant. However, it changes as you go down, so you would need to perform an integration to determine the net force.
Aha, I see. This is first fluid question I had involving integration.
Thus, I integrated \intPo + pgh dh from 0 to H.
Getting P=PaH + pgH^2/2.
Thus
PA = HW(PaH + pgH^2/2).
Better now?
anyone?
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
