Calculate steam raised per hour
  • Thread starter Thread starter Andy86
    Per Steam
The discussion revolves around calculating the amount of steam generated from flue gases produced by burning a fuel gas mixture. The fuel gas consists of butane, propane, and butene, and is combusted with 10% excess air. Participants emphasize the importance of determining the heat capacity of the flue gas mixture and accounting for heat losses in the calculations. Key equations for calculating mass flow rates and energy transfers are discussed, alongside the need for careful unit conversions and consideration of phase changes in water. Ultimately, the calculations lead to an estimated steam production rate, highlighting the complexity of thermodynamic problems in engineering.
Andy86
A fuel gas consists of 75% butane (C4H10), 10% propane (C3H8) and 15% butene (C4H8) by volume. It is to be fed to the combustion chamber in 10% excess air at 25ºC, where it is completely burnt to carbon dioxide and water. The flue gases produced are to be used to generate 5 bar steam from water at 90ºC.
(i) If 5% of the heat available for steam production is lost to the atmosphere, determine the amount of steam raised per hour when the total flow of flue gases is 1400 kmol h–1.
Water Inlet temp = 90°C (Given in question)
Steam temp @ 5bar = 152°C (from steam tables)
Flue Gas inlet = 1997°C (Based on flame temp)
Flue Gas outlet = 300°C (Given in question)
Latent heat of steam @ 5 bar = 2108KJ/KG (from steam tables)
TOT flow of flue gas = 1440 kmol h-1
Mass flow rate (H) * Heat Capacity * (ΔH) = Mass flow rate (C) * Heat Capacity (C) * (ΔC)
Rearrange to make "Mass flow rate (C)" the subject>
Mass flow rate (C) = (Mass flow rate (H) * Heat Capacity * (ΔH)) / (Heat Capacity (C) * (ΔC))
[/B]
Mass flow rate (C) = (1400 * Heat Capacity) * (1997-300) / (4.2 * (288-90))
To attempt this question I need the heat capacity of the fuel gas mix, I am not sure how to calculate this and once I do am I using the correct equation??
Thanks
Andy
Why ? Isn't this question now all about CO2 and water ?
Sorry heat capacity of flue gas
Well, you could http://www.kostic.niu.edu/350/_350-posted/350Chengel7th/Appendix1Udated.pdf :rolleyes:
They gave you a lot of little facts to string together.
Flue gas is a mix of air(10%excess), N2, CO2 and water. N2 i'd probably treat like air.
Specific heats of all are easy to look up
from given fuel mix you know how much carbon and hydrogen are there so i think you can come up with fraction of each gas
and they gave you ΔT
and flow rate in moles which should translate to mass
it's a several step problem to come up with ΔH for flue gas side, and two or three steps for steam side.
Think in little steps.
Thanks BvU & Jim, is this lot any closer?
Thanks
Andy
Heat capacities of the flue gases at 1997°C / 2270K
Co2 = 1.3865 KJ/KG
H2O = 2.41267 KJ/KG
O2 = 1.1999 KJ/KG
N2 = 1.2985 KJ/KG
Mass = Nmols * Molecular Mass
Co2 = 3.9mols * 44 = 171.6g
H2O = 4.75mols * 18 = 85.5g
O2 = 0.6mols * 32 = 19.2g
N2 = 25.9mols * 28 = 725.2g
Specific heat of flue gases
3.9 mols Co2 = 1.3865 /1000 * 171.6g = 0.24 KJ/KG
4.75 molsH2O = 2.41267 /1000 * 85.5g = 0.21 KJ/KG
0.6 mols O2 = 1.1999 /1000 * 19.2g = 0.02 KJ/KG
25.9 mols N2 = 1.2985 /1000 * 725.2g = 0.94 KJ/KG
TOTAL = 1.41KJ/KG
Allow for 5% heat loss > 1.41 KJ/KG * 0.95
= 1.34 KJ/KG
TOTAL mass = 1001.5g > 1.0015KG
TOTAL flue gas mols = 35.15 mols > 0.03515 Kmol
1001.5KG / 35.15mols = 28.49 grams per mol of flue gas
1400 kmol h^-1 (given in question)
mass h^-1 = 0.02849KG * 1400 Kmol
Flue gas mass= 39.9 KG / H
= 39.9 KG / H * 1.34 KJ/KG * (1997-300) / (4.2 * 152 - 90)
= 360 KG / HOUR
If you want someone to check your work you need to show it step by step.
Looks to me like you're slapping up equations and expecting them to work. They only work if you've got every term entered correctly.
This process cools flue gas, transferring energy to the water . I think you've got that.
Now do the footwork to get the right numbers in your formulas.
water side is easy, it comes in as liquid at 90 degrees and leaves as 5 bar steam presumably dry saturated.
So your question becomes two questions:
How much energy comes out when you cool a kg of flue gas from 1997 to 300 degrees?
How much energy goes into turn a kg of 90 degree water into 5 bar steam ? Hint - a lot more than 4.2*152-90.
From those two numbers and mass flow rate of either fluid , you can calculate flowrate of the other.
corrections welcome.
old jim
Likes BvU
old jim
Thanks for the constructive criticism >>>
Correction...
Mass = 28.9 g per mol of flue gas
Flow rate = 1400 Kmol / hour
Mass flow rate = 28.9g * (1400 * 1000)
= 39, 886 KG / hour
= 39, 886 / 3600
= 11.08 KG / Sec
q = Cp * M * ΔT
q = (1.41 KG / KJ) * (11.08 KG / Sec) * (1997 - 300)
q = 7.36 KW / S
q = 7.36 * 3600
q = 26, 511 KW / H
q = Cp * M * ΔT
Rearranged for M
M = q / Cp * ΔT
M = 26511 / 4.2 * 62
M = 101.8 KG / H
Always cross-check a calculation to see if you're using the right algorithm.
http://www.engineeringtoolbox.com/saturated-steam-properties-d_457.html
Really should use a subcooled water table for hliquid
jim hardy said:
Always cross-check a calculation to see if you're using the right algorithm.http://www.engineeringtoolbox.com/saturated-steam-properties-d_457.html
View attachment 113577Really should use a subcooled water table for hliquid
Apologies Jim, I am not sure what point your are trying to make? The question asks me for the Mass of the steam over an hour. Using the information I have I came up with M = 101.8 KG / H. Have I used an incorrect value somewhere?> I thought the heat capacity of water was constant @ 4.2 KJ /KG up to around 125°C. Since the water is fed @ 90°C I used 4.2 KJ/KG. Should I have used a different figure? I see you have very kindly highlighted 1.99 KJ/KG?? Is this the figure I should have used for Cp?
How does my figure of 108.1 KG / H look?
Sounds reasonable for heating water from 90 degrees to boiling point
I'm more accustomed to BTU's,
MCΔT is for simply heating a substance. A single BTU will heat a pound of water a single degree F
What about a phase change? Takes ~1000 BTU's to boil a pound of water into a pound of steam...
How about in SI units?
I don't see a heat of vaporization in your formula so i don't know what you are using for an algorithm.
Maybe it's in there just i missed it.
That's why it's important to work step by step defining your terms. Explain what each represents. Paint a word picture of your analysis.
I would have done the calculation very differently.
Co2 = 1.3865 KJ/KG-K = 1.3865 x 44 = 61 kJ/kmol-K
H2O = 2.41267 KJ/KG-K = 2.41267 x 18 = 43.42 kJ/kmol-K
O2 = 1.1999 KJ/KG-K = 1.1999 x 32 = 38.97 kJ/kmol-K
N2 = 1.2985 KJ/KG-K = 1.2985 x 28 = 36.36 kJ/kmol-K
Mole Fractions of gases
Co2 = 3.9mols /35.15 mols = 0.111
H2O = 4.75mols /35.15 mols = 0.135
O2 = 0.6mols /35.15 mols = 0.017
N2 = 25.9mols/35.15 mols = 0.739
Heat Capacity of mixture = (0.111)(61)+(0.135)(43.42)+(0.017)(38.97)+(0.739)(36.36)= 40.17 kJ/kmol-K
Available heat = (1400)(40.17)(1997-300)=95,400,000 kJ/hr
Heat load after 5 % loss = 90,700,000 kJ/hr
Enthalpy change per kg of steam produced = 4.184 (152-90) + 2108 = 2367 kJ/kg
Rate of steam production = 90700000/2367 = 38300 kg/hr
Likes jim hardy
@Chestermiller
Thanks Chester- that completely blows my calculations out the water! Back to square 1 we go!
Note how Chester explained what he was doing in every line
and expressed heat capacity per K
and went straight to an answer using logical small steps
old jim
Andy86 said:
@Chestermiller
Andy86: I didn't mean to discourage you. The point I was trying to make was that, rather than going back and forth between g, kg, moles, and kmol with the fuel gas, it would have been much easier to work entirely in terms of kmol (after all, the flow rate was already in terms of kmol). All you would need to have done would have been to multiply each heat capacity by the corresponding molecular weight to get the heat capacities per kmol. After that, everything could have been done in kmols.
@Chestermiller I was only joking! Thanks for stepping in, I have now completed all my thermodynamics modules. VERY steep learning curve. Thanks for all the help! @jim hardy Thank you also for the guidance! Off to sit in a darkened room for 3 hours!
Thanks
Andy
I'm still learning the ropes in homework forums...
Chester's molar method for flue gas energy is way superior to mine. I went to mass because it's my "safe zone" . I'm a chemistry plodder, out of my element...
But i was pretty sure on water side you'd missed heat of vaporization
and wanted you to go single-stepwise rather than leap into MCΔT which doesn't account for phase change.
Chestermiller said:
Enthalpy change per kg of steam produced = 4.184 (152-90)(heat feedwater to saturation temperature) + 2108(heat of vaporization) = 2367 kJ/kg
Glad you're seeing it clearly now.
Thanks @Chestermiller !
Likes Chestermiller
can I ask how you got these figures?
Co2 = 1.3865 KJ/KG
H2O = 2.41267 KJ/KG
O2 = 1.1999 KJ/KG
N2 = 1.2985 KJ/KG
Co2 = 1.3865 KJ/KG
H2O = 2.41267 KJ/KG
O2 = 1.1999 KJ/KG
N2 = 1.2985 KJ/KG
I'm struggling with that one as well.
I was going more down the route of converting 1400kmol/h to kg/h
Molecular mass of flue gas = 35.21g/kmol
=0.03521kg/kmol
##\frac{1400}{0.03521}## = 39761.43kg/h
Looked it up haha
=0.03521kg/kmol
After this, I've tried factoring into the following with the specific heat cap of my flue gas being 1.53kj/kg
qmc= ##\frac{qmh \times hfg}{cpc \times (Tc2-Tc1)}##
With hfg being my enthalpy in x0.95
Thus gives me an answer of 376000 (give or take) which is either completely incorrect or out by a factor of 10?
Please help...?
Tried again by calculating heat load of the flue gas using my kmol/h to kg/h conversion.
Then applied the 5% heat loss and tried to calculate mass flowrate :
qmc = ##\frac{Q}{(cpC (Tc2-Tc1))}##
Still leaving me out by a factor of 10 at 309253kg/h??
I'm now doubting my kmol/h to kg/h conversion.
Why won't my mass calculation pan-out?
Yep.
My kmol/h to kg/h conversion is incorrect.
Units error.
Which would make it 39.76kg/h.
This would make my answer 390.253kg/h.
Too far the other way now? Scratching brain.
=0.03521kg/kmol
What were the mole fractions of CO2, H2O, O2, and N2 you calculated for the flue gas?
Flue gas:
CO2 = 3.9. (11%)
H2O = 4.75. (13.5%)
O2 = 0.6. (0.6%)
N2 = 25.96. (25.96%)
Total 35.21
So my next step, I tried to convert kmol/h to kg/h
So ##\frac{1400}{35.21}##
= 39.76143kg/h
This meant that my specific heat capacities of the flue gas don't need converting to kj/kmol, only fractionating according to the previously identified %'s.
So:
CO2 = 1.39 x 0.111 = 0.154
H2O = 2.93 x 0.135 = 0.396
O2. = 1.2 x 0.017 = 0.0204
N2. = 1.3 x 0.737 = 0.958
Total heat capacity of flue gas = 1.53kj/kg
= 39.76143kg/h
Check the units
Flue gas heat load:
Q = qmh x cph (Th1 - Th2)
= 39.76143 x 1.53 (2050-300)
= 106461.2288kj/h
x0.95 (for 5% heat loss) = 101138.1674kj/h
Then into qmc = ##\frac{Q}{cpc \times (Tc2-Tc1)}##
  • #31
Chestermiller said:
Check the units
Sorry Chester, I know you're trying to help, but you'll have to give me a bit more than that.
I've already adjusted the units once (another previous post) - I'm missing/not grasping something.
  • #32
kmoles x (kg/kmole) = kg
  • #33
Did you really think that the flow rate in a piece of industrial equipment was only 40 kg/hr?
  • #34
I noticed it was small, especially with my steam produced being so small.
But as I haven't done any mass and energy balance modules etc or much in the way conversion kmol to kg/h, I'm just trying best I can.
  • #35
Well, one thing you must make sure about is that the units correctly cancel. This will prevent you from mutiplying when you should be dividing, or dividing when you should be multiplying.
Likes Rogue
  • #36
Thanks for that, and for pointing out that it should be a multiplication.
Think the stoichiometry has jumbled my head somewhat.
  • #37
Something still isn't quite right somewhere.
Missing a step methinks.
  • #38
Right, I think I should be adding enthalpy into the system into my qmc equation.
But I'm not sure I understand why.
Why would you divide the heat load by the heat capacity of water x dT + system enthalpy?
  • #39
Sorry, enthalpy of steam at 5bar.
I guess this tells you the energy required to produce the steam at 5bar?
Don't think I've factored this in before on other heat transfer equations though.
  • #40
Rogue said:
Flue gas:
CO2 = 3.9. (11%)
H2O = 4.75. (13.5%)
O2 = 0.6. (0.6%)
Total 35.21
I don't confirm these mole percents or your molecular weight. I get
11.06%
13.48%
1.78%
73.68%
And a molecular weight of 28.5 kg/kmole
  • #41
Now, I think I understand.
It appears that most of my other work has involved heating a substance without change of state.
During the heating, when the water (liquid) turns to steam (water -gas), additional enthalpy is required for the change of state.
This being an additional draw on the heating system needs to be factored in.
  • #42
Check out my post #12 from a year ago. This has the correct results.
Likes Rogue
  • #43
11.06%
13.48%
1.78%
73.68%
Sorry Chester, my mistake. I did have these correct but it would appear I have transferred across onto here incorrectly.
  • #44
What about the molecular weight?
What do you get for the heat load now?
  • #45
Thanks Chester.
I don't doubt your answer or replies, but I'm not willing to just copy across from something.
I need to work through it and gain the understanding where I'm lacking (I have no one to teach me or advise).
I'd rather get it wrong on my own merits then blindly repeat something.
Whilst I appreciate it might be frustrating for yourself, my posts and your replies have helped me rethink my original attempt.
  • #46
Yeh, got that. Too many pages with scribbles.
My heat load is 101276973 after 5% heat loss.
The difference coming from my flame temp difference.
Thanks Chester
  • #47
Thanks Chester
I got less than that. With the 5% heat loss, I get 90 MJ./hr
  • #48
My delta T was 1750 (2050-300), which is different to your original answer.
  • #49
Where did the 2050 come from?
Likes Rogue
  • #50
This is determined by a previous question where flame temperature needs to be calculated.
There will always be some differences in answer to this question as it has to be interpolated from a graph drawn by the student.
Accuracy will obviously depend on each student to an extent.
Any rounding errors calculating enthalpy in the fuel gas will also affect this.
