Antiderivatives of Logarithmic and Radical Functions: Can They Be Solved?
  • Thread starter Thread starter funcalys
    Antiderivatives
The discussion centers on the convergence of the improper integral \int^{+\infty}_{0} \frac{ln(x^{2}+4^{x})}{\sqrt{3x^{7}+7x^{3}}}dx. Participants highlight the complexity of finding the antiderivative analytically, with Wolfram Alpha failing to provide a solution. The comparison test is recommended as an alternative method for determining convergence by analyzing the asymptotic behavior of the integrand as x \rightarrow \infty and x \rightarrow 0. The integrand behaves asymptotically as \frac{\ln(4)}{\sqrt{3}} \, x^{-5/2}, leading to the evaluation of the convergence of \int_{1}^{\infty}{x^{-5/2} \, dx}.
  • Understanding of improper integrals and convergence tests
  • Familiarity with logarithmic and radical functions
  • Knowledge of asymptotic analysis
  • Experience with integration techniques and comparison tests
  • Study the Comparison Test for improper integrals
  • Learn about asymptotic behavior of functions in calculus
  • Explore advanced integration techniques for complex functions
  • Investigate the properties of logarithmic functions in integrals
Mathematicians, calculus students, and anyone involved in advanced integral calculus, particularly those studying convergence of improper integrals and asymptotic analysis.
funcalys
\int \frac{ln(x^{2}+4^{x})}{\sqrt{3x^{7}+7x^{^3}}}dx
X.
Wolfram Alpha seem to give no answer.
the x2 + 4x makes that impossible to do by analytic means
Actually my original problem was determining the convergence or divergence of the following improper integral:
\int^{+∞}_{0} \frac{ln(x^{2}+4^{x})}{\sqrt{3x^{7}+7x^{^3}}}dx
I split the integral into
\int^{+∞}_{1} \frac{ln(x^{2}+4^{x})}{\sqrt{3x^{7}+7x^{^3}}}dx
and \int^{1}_{0} \frac{ln(x^{2}+4^{x})}{\sqrt{3x^{7}+7x^{^3}}}dx
, calculate the antiderivatives, then evaluate the limit of them.
So if I can't calculate the antiderivative, is there any alternative way to see if this integral convergent or not ??
Tiny-Tim, how did you know that's impossible to do by analytical means? What should I google to learn more?
Do you know how to find the asymptotic behavior of your integrand for x \rightarrow \infty and x \rightarrow 0? If yes, then you may use the comparison test.
hi superg33k! :smile:
it's obvious just from looking at it … that bracket is simply too complicated for any of the known techniques to work! :redface:
once you've had lots of practice at differentiating and integrating, you'll see why :smile:
I'll start off. Let us consider the upper bound first. For x \rightarrow \infty. x^2 = o(4^x), so the logarithm in the numerator behaves as \sim x \, \ln(4). Similarly, 7 x^3 = o(3 x^7), so the expression under the square root in the denominator behaves as \sim 3 x^7. Therefore, the integrand behaves as:
<br /> \sim \frac{x \, \ln(4)}{\sqrt{3 x^7}} = \frac{\ln(4)}{\sqrt{3}} \, x^{-5/2}<br />
Do you know whether the integral:
<br /> \int_{1}^{\infty}{x^{-5/2} \, dx}<br />
is convergent or divergent?
A similar analysis can be done on the lower bound of the integral. However, what are the dominant terms in this limit?
Thank you very much, I can take it from here :D.
  • · Replies 19 ·
