MHB Calculating Determinants: Using Laplace Expansion or Echelon Form?
  • Thread starter Thread starter mathmari
    Determinants
This discussion focuses on calculating the determinants of matrices using both the Laplace expansion and echelon form methods. The matrices in question are matrix a and matrix b, with specific transformations applied to each. The participants confirm that while both methods are valid, starting with echelon form simplifies the process, especially when applying the Laplace expansion. Key rules for determinants during row operations are also highlighted, including the effects of row addition, swapping, and multiplication on the determinant value.
  • Understanding of matrix operations and properties
  • Familiarity with determinant calculations
  • Knowledge of echelon form and its implications on determinants
  • Experience with the Laplace expansion theorem
  • Study the properties of determinants in detail
  • Learn advanced techniques for calculating determinants, including LU decomposition
  • Explore applications of determinants in solving linear equations
  • Practice calculating determinants using both Laplace expansion and echelon form
Students, mathematicians, and educators involved in linear algebra, particularly those focusing on matrix theory and determinant calculations.
mathmari
MHB
Hey! :o
I want to calculate the determinants of the matrices $a=\begin{pmatrix}1 & 2 & 3 & 4 & 5 \\ 2 & 3 & 4 & 5 & 1 \\ 3 & 4 & 5 & 1 & 2 \\ 4 & 5 & 1 & 2 & 3 \\ 5 & 1 & 2 & 3 & 4\end{pmatrix}$ and $b=\begin{pmatrix}2 & 1 & -2 & 1 & 7 & 3 \\ 3 & 4 & 1 & 9 & -1 & 2 \\ 0 & 0 & 1 & 1 & 1 & 0 \\ 0 & 0 & 1 & 2 & 1 & 6 \\ 0 & 0 & 0 & 1 & 1 & -1 \\ 0 & 0 & 0 & 0 & 0 & 3\end{pmatrix}$
For that do we use the Laplace expansion theorem or can we transform these matrices firstly in echelon form and calculate the determinant then? But is the determinant of the initial matrix equal to the determinant of the matrix in echelon form? (Wondering)
Hey mathmari!
We can do both. (Nod)
If we choose the echelon form, there are a couple of special rules for determinants though.
1. We can add a multiple of a row to another.
2. If we swap 2 rows, then the sign of the determinant swaps as well.
3. If we multiply a row by a factor, then the determinant is multiplied by that factor as well.
4. We can do the same with columns instead of rows.
(Thinking)
(Thinking)
Ok! Which of the two ways do you suggest to use in this case? (Wondering)
A combination! (Happy)
Start with working towards echelon form or some such until Laplace expansion becomes easy enough.
If you reach echelon form, the Laplace expansion is just the product of the elements on the diagonal. (Thinking)
How does the determinant change in this case? Do we multiply also the determinant by this factor? Or doesn't the determinant change by using this rule? (Wondering)
The determinant does not change if we add a multiple of a row to a different row. (Emo)
Ok! So, as for the matrix $b$ we have the following:
\begin{align*}\det b=&\begin{vmatrix}2 & 1 & -2 & 1 & 7 & 3 \\ 3 & 4 & 1 & 9 & -1 & 2 \\ 0 & 0 & 1 & 1 & 1 & 0 \\ 0 & 0 & 1 & 2 & 1 & 6 \\ 0 & 0 & 0 & 1 & 1 & -1 \\ 0 & 0 & 0 & 0 & 0 & 3\end{vmatrix} \ \overset{R_2:R_2-\frac{3}{2}\cdot R_1}{=} \ \begin{vmatrix}2 & 1 & -2 & 1 & 7 & 3 \\ 0 & \frac{5}{2} & 4 & \frac{15}{2} & -\frac{23}{2} & -\frac{5}{2} \\ 0 & 0 & 1 & 1 & 1 & 0 \\ 0 & 0 & 1 & 2 & 1 & 6 \\ 0 & 0 & 0 & 1 & 1 & -1 \\ 0 & 0 & 0 & 0 & 0 & 3\end{vmatrix} \\ & \ \overset{R_4:R_4-R_3}{=} \ \begin{vmatrix}2 & 1 & -2 & 1 & 7 & 3 \\ 0 & \frac{5}{2} & 4 & \frac{15}{2} & -\frac{23}{2} & -\frac{5}{2} \\ 0 & 0 & 1 & 1 & 1 & 0 \\ 0 & 0 & 0 & 1 & 0 & 6 \\ 0 & 0 & 0 & 1 & 1 & -1 \\ 0 & 0 & 0 & 0 & 0 & 3\end{vmatrix} \ \overset{R_5:R_5-R_4}{=} \ \begin{vmatrix}2 & 1 & -2 & 1 & 7 & 3 \\ 0 & \frac{5}{2} & 4 & \frac{15}{2} & -\frac{23}{2} & -\frac{5}{2} \\ 0 & 0 & 1 & 1 & 1 & 0 \\ 0 & 0 & 0 & 1 & 0 & 6 \\ 0 & 0 & 0 & 0 & 1 & -7 \\ 0 & 0 & 0 & 0 & 0 & 3\end{vmatrix} \\ & =2\cdot \frac{5}{2}\cdot 1\cdot 1\cdot 1\cdot 3=15
\end{align*}
Right? (Wondering)
Yep. (Nod)
Yep. (Nod)
And as for matrix $a$ we have:
\begin{align*}\det a&=\begin{vmatrix}1 & 2 & 3 & 4 & 5 \\ 2 & 3 & 4 & 5 & 1 \\ 3 & 4 & 5 & 1 & 2 \\ 4 & 5 & 1 & 2 & 3 \\ 5 & 1 & 2 & 3 & 4\end{vmatrix} \ \overset{R_2:R_2-2\cdot R_1}{=} \ \begin{vmatrix}1 & 2 & 3 & 4 & 5 \\ 0 & -1 & -2 & -3 & -4 \\ 3 & 4 & 5 & 1 & 2 \\ 4 & 5 & 1 & 2 & 3 \\ 5 & 1 & 2 & 3 & 4\end{vmatrix}\\ & \ \overset{R_3:R_3-3\cdot R_1}{=} \ \begin{vmatrix}1 & 2 & 3 & 4 & 5 \\ 0 & -1 & -2 & -3 & -4 \\ 0 & -2 & -4 & -11 & -13 \\ 4 & 5 & 1 & 2 & 3 \\ 5 & 1 & 2 & 3 & 4\end{vmatrix} \ \overset{R_4:R_4-4\cdot R_1}{=} \ \begin{vmatrix}1 & 2 & 3 & 4 & 5 \\ 0 & -1 & -2 & -3 & -4 \\ 0 & -2 & -4 & -11 & -13 \\ 0 & -3 & -11 & -14 & -17 \\ 5 & 1 & 2 & 3 & 4\end{vmatrix} \\ & \ \overset{R_5:R_5-5\cdot R_1}{=} \ \begin{vmatrix}1 & 2 & 3 & 4 & 5 \\ 0 & -1 & -2 & -3 & -4 \\ 0 & -2 & -4 & -11 & -13 \\ 0 & -3 & -11 & -14 & -17 \\ 0 & -9 & -13 & -17 & -21\end{vmatrix} \ \overset{R_3:R_3-2\cdot R_2}{=} \ \begin{vmatrix}1 & 2 & 3 & 4 & 5 \\ 0 & -1 & -2 & -3 & -4 \\ 0 & 0 & 0 & -5 & -5 \\ 0 & -3 & -11 & -14 & -17 \\ 0 & -9 & -13 & -17 & -21\end{vmatrix} \\ & \ \overset{R_4:R_4-3\cdot R_2}{=} \ \begin{vmatrix}1 & 2 & 3 & 4 & 5 \\ 0 & -1 & -2 & -3 & -4 \\ 0 & 0 & 0 & -5 & -5 \\ 0 & 0 & -2 & -5 & -5 \\ 0 & -9 & -13 & -17 & -21\end{vmatrix} \ \overset{R_5:R_5-9\cdot R_2}{=} \ \begin{vmatrix}1 & 2 & 3 & 4 & 5 \\ 0 & -1 & -2 & -3 & -4 \\ 0 & 0 & 0 & -5 & -5 \\ 0 & 0 & -2 & -5 & -5 \\ 0 & 0 & 5 & 10 & 15\end{vmatrix} \\ & \ \overset{R_5:R_5+\frac{5}{2}\cdot R_4}{=} \ \begin{vmatrix}1 & 2 & 3 & 4 & 5 \\ 0 & -1 & -2 & -3 & -4 \\ 0 & 0 & 0 & -5 & -5 \\ 0 & 0 & -2 & -5 & -5 \\ 0 & 0 & 0 & -\frac{5}{2} & \frac{5}{2}\end{vmatrix} \ \overset{R_5:R_5-\frac{1}{2}\cdot R_3}{=} \ \begin{vmatrix}1 & 2 & 3 & 4 & 5 \\ 0 & -1 & -2 & -3 & -4 \\ 0 & 0 & 0 & -5 & -5 \\ 0 & 0 & -2 & -5 & -5 \\ 0 & 0 & 0 & 0 & 5\end{vmatrix} \\ & \ \overset{R_3\leftrightarrow R_4}{=} \ -\begin{vmatrix}1 & 2 & 3 & 4 & 5 \\ 0 & -1 & -2 & -3 & -4 \\ 0 & 0 & -2 & -5 & -5 \\ 0 & 0 & 0 & -5 & -5 \\ 0 & 0 & 0 & 0 & 5\end{vmatrix}=-1\cdot (-1)\cdot (-2)\cdot (-5)\cdot 5=50
\end{align*}
Is this correct? And is this the way you meant or is there a better/faster way if we use also the Laplace expansion? (Wondering)
\end{align*}
Shouldn't that be
\begin{align*}\det a&=\begin{vmatrix}1 & 2 & 3 & 4 & 5 \\ 2 & 3 & 4 & 5 & 1 \\ 3 & 4 & 5 & 1 & 2 \\ 4 & 5 & 1 & 2 & 3 \\ 5 & 1 & 2 & 3 & 4\end{vmatrix} \ \overset{R_2:R_2-2\cdot R_1}{=} \ \begin{vmatrix}1 & 2 & 3 & 4 & 5 \\ 0 & -1 & -2 & -3 & {\color{red}\mathbf{-\enclose{circle}{9}}} \\ 3 & 4 & 5 & 1 & 2 \\ 4 & 5 & 1 & 2 & 3 \\ 5 & 1 & 2 & 3 & 4\end{vmatrix}
\end{align*}
(Worried)
This is the way yes. I think it is the fastest way to calculate this determinant. (Thinking)
Shouldn't that be
\end{align*}
(Worried)
Now I get
\begin{align*}\det a&=\begin{vmatrix}1 & 2 & 3 & 4 & 5 \\ 2 & 3 & 4 & 5 & 1 \\ 3 & 4 & 5 & 1 & 2 \\ 4 & 5 & 1 & 2 & 3 \\ 5 & 1 & 2 & 3 & 4\end{vmatrix} \ \overset{R_2:R_2-2\cdot R_1}{=} \ \begin{vmatrix}1 & 2 & 3 & 4 & 5 \\ 0 & -1 & -2 & -3 & -9 \\ 3 & 4 & 5 & 1 & 2 \\ 4 & 5 & 1 & 2 & 3 \\ 5 & 1 & 2 & 3 & 4\end{vmatrix}\\ & \ \overset{R_3:R_3-3\cdot R_1}{=} \ \begin{vmatrix}1 & 2 & 3 & 4 & 5 \\ 0 & -1 & -2 & -3 & -9 \\ 0 & -2 & -4 & -11 & -13 \\ 4 & 5 & 1 & 2 & 3 \\ 5 & 1 & 2 & 3 & 4\end{vmatrix} \ \overset{R_4:R_4-4\cdot R_1}{=} \ \begin{vmatrix}1 & 2 & 3 & 4 & 5 \\ 0 & -1 & -2 & -3 & -9 \\ 0 & -2 & -4 & -11 & -13 \\ 0 & -3 & -11 & -14 & -17 \\ 5 & 1 & 2 & 3 & 4\end{vmatrix} \\ & \ \overset{R_5:R_5-5\cdot R_1}{=} \ \begin{vmatrix}1 & 2 & 3 & 4 & 5 \\ 0 & -1 & -2 & -3 & -9 \\ 0 & -2 & -4 & -11 & -13 \\ 0 & -3 & -11 & -14 & -17 \\ 0 & -9 & -13 & -17 & -21\end{vmatrix} \ \overset{R_3:R_3-2\cdot R_2}{=} \ \begin{vmatrix}1 & 2 & 3 & 4 & 5 \\ 0 & -1 & -2 & -3 & -9 \\ 0 & 0 & 0 & -5 & 5 \\ 0 & -3 & -11 & -14 & -17 \\ 0 & -9 & -13 & -17 & -21\end{vmatrix} \\ & \ \overset{R_4:R_4-3\cdot R_2}{=} \ \begin{vmatrix}1 & 2 & 3 & 4 & 5 \\ 0 & -1 & -2 & -3 & -9 \\ 0 & 0 & 0 & -5 & 5 \\ 0 & 0 & -2 & -5 & 10 \\ 0 & -9 & -13 & -17 & -21\end{vmatrix} \ \overset{R_5:R_5-9\cdot R_2}{=} \ \begin{vmatrix}1 & 2 & 3 & 4 & 5 \\ 0 & -1 & -2 & -3 & -9 \\ 0 & 0 & 0 & -5 & 5 \\ 0 & 0 & -2 & -5 & 10 \\ 0 & 0 & 5 & 10 & 60\end{vmatrix} \\ & \ \overset{R_5:R_5+\frac{5}{2}\cdot R_4}{=} \ \begin{vmatrix}1 & 2 & 3 & 4 & 5 \\ 0 & -1 & -2 & -3 & -9 \\ 0 & 0 & 0 & -5 & 5 \\ 0 & 0 & -2 & -5 & 10 \\ 0 & 0 & 0 & -\frac{5}{2} & 85\end{vmatrix} \ \overset{R_5:R_5-\frac{1}{2}\cdot R_3}{=} \ \begin{vmatrix}1 & 2 & 3 & 4 & 5 \\ 0 & -1 & -2 & -3 & -9 \\ 0 & 0 & 0 & -5 & 5 \\ 0 & 0 & -2 & -5 & 10 \\ 0 & 0 & 0 & 0 & \frac{165}{2}\end{vmatrix} \\ & \ \overset{R_3\leftrightarrow R_4}{=} \ -\begin{vmatrix}1 & 2 & 3 & 4 & 5 \\ 0 & -1 & -2 & -3 & -9 \\ 0 & 0 & -2 & -5 & 10 \\ 0 & 0 & 0 & -5 & 5 \\ 0 & 0 & 0 & 0 & \frac{165}{2}\end{vmatrix}=-1\cdot (-1)\cdot (-2)\cdot (-5)\cdot \frac{165}{2}=825
\end{align*}
But according to Wolfram the result is $1875$ but I don't see where I could have done something wrong. Do you maybe have an idea? (Wondering)
mathmari said:
\begin{align*}\begin{vmatrix}1 & 2 & 3 & 4 & 5 \\ 0 & -1 & -2 & -3 & -9 \\ 0 & 0 & 0 & -5 & 5 \\ 0 & -3 & -11 & -14 & -17 \\ 0 & -9 & -13 & -17 & -21\end{vmatrix} & \ \overset{R_4:R_4-3\cdot R_2}{=} \
\begin{vmatrix}1 & 2 & 3 & 4 & 5 \\ 0 & -1 & -2 & -3 & -9 \\ 0 & 0 & 0 & -5 & 5 \\ 0 & 0 & -2 & -5 & 10 \\ 0 & -9 & -13 & -17 & -21\end{vmatrix}\end{align*}
Shouldn't it be:
\begin{vmatrix}1 & 2 & 3 & 4 & 5 \\ 0 & -1 & -2 & -3 & -9 \\ 0 & 0 & 0 & -5 & 5 \\ 0 & 0 & {\color{red}-\enclose{circle}{5}} & -5 & 10 \\ 0 & -9 & -13 & -17 & -21\end{vmatrix}\end{align*}
(Worried)
Shouldn't it be:
(Worried)
Oh yes! So it must be as follows:
\begin{align*}\det a&=\begin{vmatrix}1 & 2 & 3 & 4 & 5 \\ 2 & 3 & 4 & 5 & 1 \\ 3 & 4 & 5 & 1 & 2 \\ 4 & 5 & 1 & 2 & 3 \\ 5 & 1 & 2 & 3 & 4\end{vmatrix} \ \overset{R_2:R_2-2\cdot R_1}{=} \ \begin{vmatrix}1 & 2 & 3 & 4 & 5 \\ 0 & -1 & -2 & -3 & -9 \\ 3 & 4 & 5 & 1 & 2 \\ 4 & 5 & 1 & 2 & 3 \\ 5 & 1 & 2 & 3 & 4\end{vmatrix}\\ & \ \overset{R_3:R_3-3\cdot R_1}{=} \ \begin{vmatrix}1 & 2 & 3 & 4 & 5 \\ 0 & -1 & -2 & -3 & -9 \\ 0 & -2 & -4 & -11 & -13 \\ 4 & 5 & 1 & 2 & 3 \\ 5 & 1 & 2 & 3 & 4\end{vmatrix} \ \overset{R_4:R_4-4\cdot R_1}{=} \ \begin{vmatrix}1 & 2 & 3 & 4 & 5 \\ 0 & -1 & -2 & -3 & -9 \\ 0 & -2 & -4 & -11 & -13 \\ 0 & -3 & -11 & -14 & -17 \\ 5 & 1 & 2 & 3 & 4\end{vmatrix} \\ & \ \overset{R_5:R_5-5\cdot R_1}{=} \ \begin{vmatrix}1 & 2 & 3 & 4 & 5 \\ 0 & -1 & -2 & -3 & -9 \\ 0 & -2 & -4 & -11 & -13 \\ 0 & -3 & -11 & -14 & -17 \\ 0 & -9 & -13 & -17 & -21\end{vmatrix} \ \overset{R_3:R_3-2\cdot R_2}{=} \ \begin{vmatrix}1 & 2 & 3 & 4 & 5 \\ 0 & -1 & -2 & -3 & -9 \\ 0 & 0 & 0 & -5 & 5 \\ 0 & -3 & -11 & -14 & -17 \\ 0 & -9 & -13 & -17 & -21\end{vmatrix} \\ & \ \overset{R_4:R_4-3\cdot R_2}{=} \ \begin{vmatrix}1 & 2 & 3 & 4 & 5 \\ 0 & -1 & -2 & -3 & -9 \\ 0 & 0 & 0 & -5 & 5 \\ 0 & 0 & -5 & -5 & 10 \\ 0 & -9 & -13 & -17 & -21\end{vmatrix} \ \overset{R_5:R_5-9\cdot R_2}{=} \ \begin{vmatrix}1 & 2 & 3 & 4 & 5 \\ 0 & -1 & -2 & -3 & -9 \\ 0 & 0 & 0 & -5 & 5 \\ 0 & 0 & -5 & -5 & 10 \\ 0 & 0 & 5 & 10 & 60\end{vmatrix} \\ & \ \overset{R_5:R_5+R_4}{=} \ \begin{vmatrix}1 & 2 & 3 & 4 & 5 \\ 0 & -1 & -2 & -3 & -9 \\ 0 & 0 & 0 & -5 & 5 \\ 0 & 0 & -5 & -5 & 10 \\ 0 & 0 & 0 & 5 & 70\end{vmatrix} \ \overset{R_5:R_5+ R_3}{=} \ \begin{vmatrix}1 & 2 & 3 & 4 & 5 \\ 0 & -1 & -2 & -3 & -9 \\ 0 & 0 & 0 & -5 & 5 \\ 0 & 0 & -5 & -5 & 10 \\ 0 & 0 & 0 & 0 & 75\end{vmatrix} \\ & \ \overset{R_3\leftrightarrow R_4}{=} \ -\begin{vmatrix}1 & 2 & 3 & 4 & 5 \\ 0 & -1 & -2 & -3 & -9 \\ 0 & 0 & -5 & -5 & 10 \\ 0 & 0 & 0 & -5 & 5 \\ 0 & 0 & 0 & 0 & 75\end{vmatrix}=-1\cdot (-1)\cdot (-5)\cdot (-5)\cdot 75=1875
\end{align*}
Now the result is correct (Malthe)
Nice! (Cake)
