Calculate the efficiency of a furnace’s heat transfer process
The discussion focuses on calculating the efficiency of a propane-fueled aluminium furnace used to melt four aluminium ingots, each weighing 22.5 kg. The calorific value of propane is established at 49.93 MJ/kg, and the total energy required to melt the ingots is calculated to be 20,326.5 kJ. The participant seeks clarification on how to compute the efficiency based on the energy available from 2.1 kg of propane, which yields 104.853 MJ. The key takeaway is that the efficiency can be determined by comparing the energy required to melt the aluminium with the energy provided by the propane.
  • Understanding of thermodynamics principles, specifically heat transfer.
  • Familiarity with specific heat capacity and latent heat concepts.
  • Knowledge of energy units, including kJ and MJ.
  • Basic algebra for calculating efficiency ratios.
  • Research the formula for calculating thermal efficiency in heat transfer processes.
  • Study the specific heat capacity and latent heat of various materials, particularly metals.
  • Explore the principles of calorimetry and its applications in industrial processes.
  • Learn about the combustion properties of propane and its efficiency in heating applications.
Students in physics or engineering fields, professionals involved in metallurgy, and anyone interested in optimizing furnace operations for metal melting processes.
Gregs6799
[/B]
Hi guys.
Been looking at this question for a while and can't figure it out.
An aluminium furnace is fuelled with propane gas. The furnace is loaded up with 4 aluminium ingots each of mass 22.5 kg.
The question is:
If 2.1 kg of propane is used to complete the melting process calculate the efficiency of the furnace’s heat transfer process.
[/B]
Calorific value for propane 49.93 MJ/kg.
[/B]
From an earlier question I worked out the following:
660 – 20 = 640
22.5 x 0.91 x 640 = 13,104 kJ
Melting point = 13,104 kJ
321 x 22.5 = 7,222.5
Boiling point = 7,222.5 kJ
Total energy = 13,104 + 7,222.5 = 20,326.5 kJ
So far I've played around with the values:
49.93 x 22.5 = 1,123.425 MJ or kg
49.93 x 2.1 = 104.853 MJ or kg
Do I have to replace the original melting point answer with one of the above answers?
I'm very new to physics so any help very much appreciated.
Thanks.
Step at a time: how much heat do you need; how much heat is available?
Gregs6799 said:
660 – 20 = 640
True, but what do these numbers represent?
Gregs6799 said:
22.5 x 0.91 x 640
What is the 0.91?
A melting point would be a temperature, not a quantity of energy.
Gregs6799 said:
321
What's this?
It looks like you calculated the amount of heat required to melt the aluminum bars correctly, and your second calculation (involving the 2.1 kg) gives the heat available from the propane correctly. So, what is the efficiency?
Haruspex,
660 = melting temperature of aluminium, minus 20 as the ingots are stored at that temperature
0.91 = Specific heat capacity for aluminium (cp):
321 = Latent heat of melting for aluminium (L): kJ/kg
I need 13104 kJ to melt the ingots, or 20,326.5 kJ with the boiling point, and I have 104.853 MJ (104853 kj) from the propane, so I'm assuming that its very effective to achieve the objective?
Also apologies for confusing units of energy with temperature units.
Gregs6799 said:
Haruspex,
Ok, so in
presumably you meant energy to reach melting point, and in
you meant energy to melt the aluminium. (Boiling?!)
Don't forget there are four bars.
What is the logic behind this calculation:
and how can it result in either MJ or kg?
13,104 kj is the melting point
7,222.5 kj to reach boiling point, I assumed you needed both units for the correct answer not just the melting point.
So I'm using the 13,104 x 4 = 52,416 kj?
Calorific value for propane = 49.93 MJ/kg that's why I did 49.93 x 22.5 (weight of the bars) to get 1,123.425 kg, I put MJ as was unsure if the answer was going to be weight or energy.
As I said, very new to physics.
Appreciated.
That's 49.93 MJ per kg of propane, not aluminum.
The aluminium melts. It does not get anywhere near boiling.
  • · Replies 16 ·
9K
