Calculate the force F necessary to keep the velocity constant.
The discussion centers on calculating the forces acting on a 10-kilogram block moving on a rough horizontal surface with a coefficient of sliding friction of 0.2. To maintain a constant velocity of 6.0 meters per second, the necessary force F must counteract friction, which totals 20 Newtons. When the force is increased to F', resulting in a 60 joule increase in kinetic energy over a distance of 4.0 meters, the work-energy theorem must be applied to determine the new force and acceleration. The kinetic energy calculations and the distinction between force and energy are critical to solving the problem.
  • Understanding of Newton's First Law of Motion
  • Familiarity with the work-energy theorem
  • Knowledge of basic physics concepts such as force, friction, and kinetic energy
  • Ability to perform calculations involving mass, acceleration, and energy
  • Study the work-energy theorem in detail
  • Learn how to calculate frictional forces in various scenarios
  • Explore the relationship between force, work, and energy
  • Practice problems involving constant velocity and acceleration in physics
Students studying physics, educators teaching mechanics, and anyone interested in understanding the dynamics of forces and motion on surfaces.
AraProdieur
I need help!
Ok, so here's the problem.
A 10-kilogram block is pushed along a rough horizontal surface by a constant horizontal force F as shown above. At time t=0, the velocity v of the block is 6.0 meters per second in the same direction as the force. The coefficient of sliding friction is 0.2. Assume g= 10 meters per second squared.
A) Calculate the force F necessary to keep the velocity constant.
The force is now changed to a larger constant value F'. The block accelerates so that its kinetic energy increases by 60 joules while it slides a distance of 4.0 meters.
B) Calculate the force F'.
C) Calculate the acceleration of the block.
Ok, so far I have that the work done by kinetic energy is 1/2mv^2 by which would be simplified to 180 Joules. Since there is friction involved, I would account for the Force of friction which is the coefficient of friction multiplied by the normal force in which the total would be 2.
Now would the force F be 180 Joules to keep it constant?
and for B since the kinetic energy is increased by 60 Joules, then the total kinetic energy put on the object would be 240 Joules. So would that be force F'?
and for the acceleration of the block, would I use V^2= Vo^2 + 2a(deltax)?
the normal force is mg which is 100 Newtons, so the friction force is 20 Newtons.
you are confusing force with energy. What does Newton 1 tell you about objects moving at constant velocity? What then must be the applied force F?
you can't equate force and energy, they are 2 different animals. Are you familiar with the work-energy theorem, which states that the work done by all forces acting on the block must be equal to the change in Kinetic energy of the block?
So then how would I go about solving these problems?
  • · Replies 16 ·
  • · Replies 37 ·
