Calculate the frictional torque of the record player
  • Thread starter Thread starter Noor123
    Torque
7 replies · 5K views
Noor123
URGENT! rotational kinematics
A record player is spinning at 33 rpm when the motor is switched off. After 5.9 seconds the angular speed has decreased to 20 rpm. Calculate the frictional torque if the record player can be treated as a solid wheel of mass 5.5 kg and radius 14 cm.
A. 1187.62712 Nm
B.0.01244 Nm
C. 0.04752 Nm
D. 2375.25424 Nm
E. 0.11876 Nm
Which one?
Show us your work. We don't give out answers here. We will help you figure it out.
omege final = 3.45 rad/sec
omega initial = 2.094 rad/sec
omega final = omega initial + alpha x delta t
2.094 = 3.45 + 5.9 alpha
alpha = -0.230
torque = I x alpha
mR^2 x alpha
(0.1078) (-0.229)
= -0.02468
?? none of these answers
You are not using the right moment of inertia. For a solid wheel it should be 0.5MR^2.
Ok what about this?
PLZ QUICK
A solid sphere of mass 4.0 kg and radius 0.12 m starts from rest at the top of a ramp inclined 15 degrees, and rolls without slipping to the bottom. The upper end of the ramp is 2.7 m higher than the lower end. What is the linear speed of the sphere when it reaches the bottom of the ramp?
A. 132.3 m/s
B. 6.15 m/s
C. 7.27 m/s
D. 7.67 m/s
E. 37.8 m/s
i 've tried PE = 1/2 mv2 + 1/2 Iw2
but nothing worked please HELP!
