Calculate the initial velocity of the elevator
The discussion revolves around calculating the initial velocity of a descending elevator that is uniformly decelerated to rest. The problem involves concepts from mechanics, specifically forces, acceleration, and kinematics.
  • Mixed
  • Participants explore the relationship between tension, mass, and acceleration, with some suggesting the use of kinematic equations to find the initial velocity. Others mention the possibility of using work-energy principles, although not all participants are familiar with this method.
There is an ongoing exploration of the problem, with participants sharing their calculations for acceleration and discussing the signs to use in kinematic equations. Some participants express confusion regarding the application of formulas and the interpretation of variables.
Participants note that they have not covered certain concepts, such as work-energy, and there are discussions about the correct application of signs in equations. There is also mention of converting units, which adds to the complexity of the problem.
anglum
A descending elevator of mass 290kg is uniformly decelerated to rest over a distance of 4m by a cable in which the tension is 3631N
the acceleration due to gravity is 9.8m/s^2
calculate the initial velocity of the elevator at the beginning of the 4m descent
answer in units of m/s
i am confused on this one due to the introduction of velocity
using what we did in the last problem where T = MA + MG
3691 = 290A + 290(9.8)
A = 2.720
so now we have the acceleration
First find the acceleration using forces... then you can find the initial velocity using kinematics.
There's also a method to do it using work/energy (have you covered this yet?)
A = 2.720
good. now use kinematics to get the initial velocity. careful about signs.
we haven't covered work/energy
so i found the acceleration to be 2.720
so i have Vf= 0, Vi =?, A = 2.720, D = 4m
so now i can solve for Vi correct?
do i give the 2.720a negative sign
and then use the formula
Vf^2 = Vi^2 + 2AD
Vf^2 = Vi^2 + 2AD
yes, use this formula. acceleration is positivie. d is negative.
ok so i get Vi = 4.66535 m/s ?
looks good.
ok 2 more left if u got the time ur my saviour
A person weighing .8kN rides in an elevator that has a downward acceleration of 1.9m/s^2
the acceleration of gravity is 9.8m/s^2
what is the magnitude of the force of the elevator floor on the person??
answer in units of kN
what is kN?
do i do this one like the last problem?
what is kN?
it's very similar to the last problem... just that instead of tension, you have the normal force that the elevator exerts upward on the person. again be careful about signs.
1000N = 1kN.
so i can solve it like this
X = Normal Force
X = MA + MG
X= (.8)(1.9) + (.8)(9.8)
X = 9.36kN
or did i screw up the signs again
X = Normal Force
X = MA + MG
X = 9.36kN
0.8kN is the weight, not the mass...
also a = -1.9m/s^2
ahh so i have to convert that weight to mass... and then solve using the equation i had used
so the new equation looks like this
X = (.081kN)(-1.9m/s^2) + (.081kN)(-9.8)
or was the -9.8 supposed to be positive
where X would equal .6444
no...
I recommend working the whole problem in N and then converting to kN at the end...
The weight is 0.8kN = 800N. what is the mass in kg?
Also, you already know the weight (ie mg) is 0.8kN = 800N
X = mass*(-1.9) + 800N
if you are confused about signs and directions, start at the freebody diagram.
ahhh ok my conversions were off
so mass is 81.63 N
so then X = -155.1020408N + 800N
X = 644.89795 N
X = .64489795 kN
ok i got that one
one last problem
Take the mass of the Earth to be 5.98*10^24 kg.
If the earhts gravitation force casues a falling 65kg student to accelerate downward at 9.8m/s^2, determine the upward acceleration of the Earth during the students fall. answer in units of m/s^2
so mass is 81.63 N
X = 644.89795 N
X = .64489795 kN
yeah, that looks right.
anglum said:
ok i got that one
one last problem
What is the force the Earth exerts on the student? What is the force the student exerts on the earth?
this last problem i just posted is it similar in how i solve as the last one?
force from Earth is = MA + MG
but i don't have A
force for student is MA + MG
65*9.8 + 65*9.8
no, this one is more conceptual.
are my formulas for the force of each right or no
but i don't have A
65*9.8 + 65*9.8
no... it's not like that... don't get caught up in just using ma + mg blindly... that only worked in very specific cases. always draw a freebody diagram first... better not to take shortcuts... it will lead to mistakes.
so the acceleration for the student is 9.8m/s right? and his mass is 65kg
and i have the Earth's mass but not the acceleration
Yes... what is the force the Earth exerts on the student?
  • · Replies 35 ·
  • · Replies 22 ·
