Calculate the maximum charge that can be stored in the capacitor
The discussion revolves around calculating the maximum charge that can be stored in a parallel plate capacitor with a dielectric. The relevant parameters include a plate area of 3.00 cm², a dielectric constant of 2.40, and a dielectric strength of 5.00 kV/mm. Participants explore equations for capacitance and electric field, emphasizing the need to determine the distance between the plates. Clarifications on unit conversions and the significance of surface charge density are also addressed, leading to a resolution of the problem. Ultimately, the maximum charge calculated is 31.9 nC.
unhip_crayon
Each plate of a parallel plate capacitor has an area of 3.00 cm2. A dielectric material with
dielectric constant κ = 2.40 and a dielectric strength of 5.00 kV/mm is placed between the plates.
Calculate the maximum charge that can be stored in the capacitor.
Answer: 31.9 nC
C=(K\epsilonA)/d
and I know that E=V/d
K=2.4
\epsilon=8.85*10^-12
A=0.3
E=5.00
but i can't find d, which is what i probably need
Note that the effective electric field, E_f can be written as,
E_f = E_0-E_p
Where E_p is the electric field due to the polarisation charges in the dielectric and E_0 is the electric field in the absence of a dielectric material.
is there another method of approaching this question? I don't believe we've learned this.
Could you expand your equatiion please
How much physics have you done? Have you worked with Gaussian surfaces and Gauss' law before?
i missed a week of school when I tore a ligament in my ankle so I missed those lectures, but I do have the notes and I know about gauss' law
E=q/E0A
Could you please just start me off, I have exams coming up
E=q/E0A
It can be shown that the electric field of a dielectric capacitor may be written thus,
E = \frac{\sigma}{\kappa \varepsilon_0}
Where \sigma is the surface charge density and \kappa is the dielectric constant. If I have a little more time this evening I'll post a write up of how it is derived (or you could just look at your notes).
that formula is nowhere in our notes...hmm. I'm going to ask a buddy of mine for the solution, but if you don't mind could you post you method too.
Surface charge density...is that a constant?
I'm afraid until you've answered the question, forum guidelines prohibit me from posting the derivation.
Yes, once the capacitor is charged and the dielectric is inserted, the charge density is constant.
so what is the charge density?
The [surface] charge density on a plate is the total charge on the plate divided by the plate's area.
Is this right
Total charge on plate is q= E*E0A -- gauss' law
Plates area is, of course, 3.00
unhip_crayon said:
Is this right
That is only true in the absence of a dielectric material.
first off, id like to thank you for your help, I am learning a lot.
the only formulas i have for a dielectric material are:
E = 1/2(qV) = 1/2(q0)(V0/k) = E0/k
C=q/v = qk/V0 = kC0
C=q/v = qk/V0 = kC0
I'm sorry I think I've just dragged you the long way round. Going back to the two equations in your OP,
unhip_crayon said:
C=(K\epsilonA)/d
Can you think of a way of eliminating d from the first equation using the second?
And this equation,
unhip_crayon said:
C=q/v
may also come in handy at some point :wink:
And this equation,
haha yes, yes i can.
I had a feeling there was another, easier method. Thanks for you help
No problem :smile:
I got the answer, but I have a question. Why do we use 3.00cm^2 instead of m^2
I'm not sure what you mean, it doesn't matter which units one uses provided one converts them all to the same type. However, I noticed in your OP that,
A=0.3
You should note that 3cm^2 \neq 0.3m^2.
