Calculate the radius of gyration for a plane figure
  • Thread starter Thread starter shishykish
The discussion revolves around calculating the radius of gyration for a plane figure defined by the curve xy = 4, bounded by the x-axis and vertical lines at x = 2 and x = 4. Participants are exploring the mathematical principles and equations related to the moment of area and the radius of gyration.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants are discussing the formula for the moment of area and questioning the term for the radius of gyration squared, specifically why it is expressed as y²/3. There are also inquiries about the radius of gyration for a uniform rod and its derivation.
The conversation includes multiple interpretations of the radius of gyration and its application to the given problem. Some participants suggest clarifying the axis of rotation for the calculation, while others emphasize the importance of conceptual understanding and integration in approaching the problem.
There are mentions of LaTeX formatting corrections and the need for clarity regarding the axis of rotation in the problem statement. Participants are also considering the implications of using standard results versus deriving from first principles.
shishykish
A plane figure is bounded by the curve xy = 4, the x-axis and the ordinates at x = 2 and x =4. Calculate
$$I = Ak^2$$
$$xy=4$$
Limits of x= 2 to x=4
Area of strip = $$/delta x /times y$$
Moment of area for strip $$= Area /times (radius of gyration)^2 $$
$$ = /delta x /times y /times (/frac{y^2}{3})^2 $$
Why is the radius of gyration squared term $$y^2$ over 3? $$
shishykish said:
Homework Statement: A plane figure is bounded by the curve xy = 4, the x-axis and the ordinates at x = 2 and x =4. Calculate
Relevant Equations: $$I = Ak^2$$
$$xy=4$$
Area of strip = $$\delta x \times y$$
Moment of area for strip $$= Area \times (radius of gyration)^2 $$
$$ = \delta x \times y \times (\frac{y^2}{3})^2 $$
I have corrected your LaTeX symbols from "/" to "\".
Presumably you meant ## \delta x \times y \times (\frac{y^2}{3})##
shishykish said:
Why is the radius of gyration squared term $$y^2/ 3$$?
What is the radius of gyration of a uniform rod?
radius of gyration for a uniform rod is $$ k= \sqrt{ \frac{a^3}{3} }$$from what I remember of deriving it from my notes. So we are actually taking this shape as an elementary strip between the limits of 2 to 4. The total moment of area will be the $$ I_{area} = area \times (radius of gyration)^2 $$
Presumably the missing phrase at the end of the sentence is something like: "the radius of gyration about the x-axis".
It is important that the required axis of rotation is clear. For example it could easily be the axis perpendicular to the plane passing through the centre of mass.
Ha! Yes it is. I really could learn how to copy and paste properly!
Hi! So I should be thinking conceptually in terms of calculus. Taking an elementary shape then summing over the whole object is one of the most basic approaches.
That’s dimensionality wrong. Is it a typo?
Yes, but it is ok to use standard results too. In this problem you have a nonstandard 2D shape that can be represented as a collection of 1D standard shapes - thin rectangular strips that can be taken to be so thin as to be 1D rods.
Work from first principles (the radius of gyration of a point mass at a given distance from an axis) and integrate twice, or skip the first integration by quoting the result for a 1D rod.
  • · Replies 18 ·
